Community Member
Multicast v. Unicast in PIX515E for Microsoft NLB
Please forgive me if this is a very stupid question.
We have a PIX515E at 6.3(4) with a Windows server behind it. This server is running Citrix web interface as a portal to our farm on the internal network. Our Windows/Citrix admin is planning to add another server and set up NLB. He's asking if the PIX can support unicast or multicast.
I believe from what I've read that the PIX will support either, but I'm not clear on what I need to configure to make this work. I'm also not sure if we can support NLB if we use only static routing on the PIX. All servers and firewalls are connected to 6509 switches running EIGRP.
I'd appreciate any help or advice you can provide. Thank you!
Silver
Re: Multicast v. Unicast in PIX515E for Microsoft NLB
PIX do not support multicast, unless the source addresses of the multicast traffic are not in the address pool to be translated
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_62/relnotes/pixrn622.htm#wp88530
Community Member
Thank you for responding. We are not using NAT. I searched the forum and found that multicast was supported in the PIX515 as of 6.2, so I do believe it's supported. And I found a post that stated static routing can be used with multicast. So, I think it's possible, possibly with some config changes. If anyone out there knows of a document with examples, please reply. Thank you.
261
