multilayer switch(cef) connected to another switch.
sarahr202
Level 5
Level 5
Hi every body!
Scenario #1
Let say two switches(MLS),sw1 and sw2 are connected to each other by f0/1 ports.
. 199.199.199.0/24
sw1 f0/1-------------- f0/1 sw2
where:
199.199.199.1 ---sw1'f0/1
199.199.199.2----- sw2'f0/1
Then
sw1# show ip route
199.199.199.0/24 directly connected via f0/1.
sw1# show ip cef.
prefix next hop interface
199.199.199.0/24 attached f0/1
199.199.199.0/32 receive
199.199.199.1/32 receive.
199.199.199.255/32 receive.
Would there be another entry for directly connected sw2 i.e 199.199.199.2?
My undestanding is If sw2 has not sent any ip packets and cdp is disabled, there should not be any such entry. However my book shows the entry for directly connected sw2 in output:
Book out put:
199.199.199.2/32 199.199.199.2/32 f0/1
Am I correct in saying the entry 199.199.199.2 is present because ip packet was received from sw2 by sw1?
If i am correct, when sw1 has not recived any ip packet,cdp packets, then fib should be
sw1# show ip cef
Since there is no entry for 199.199.199.2, any packet destined to 199.199.199.2 will be process switched(by router).
AS the packet is forwarded to 199.199.199.2, Adjacency for 199.199.199.2 is build and an entry is also added to cef in sw1.Now fib in sw1 should have entry for 199.199.199.2/32.
Any subsequent packets to 199.199.199.2 will be cef-switched.
Am i correct?
thanks a lot!
2 Accepted Solutions
Edison Ortiz
Sarah,
Correct
Rack1SW1#sh ip cef | i 199
199.199.199.0/24 attached FastEthernet0/13
Rack1SW1#
Rack9Pod1>2
[Resuming connection 2 to sw2 ... ]
Rack1SW2(config-if)#
Rack1SW2(config-if)#do ping 199.199.199.1
Sending 5, 100-byte ICMP Echos to 199.199.199.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/9 ms
Rack9Pod1>1
[Resuming connection 1 to sw1 ... ]
199.199.199.2/32 attached FastEthernet0/13
The fib had an entry already for that subnet with the following entry;
In a nutshell, that's the information from the RIB.
a more specific entry was entered into the fib once the directly connected device responded to an ARP request, in this case a ICMP reply.
HTH,
__
Edison.
7 Replies 7
Jon Marshall
Sarah
I will add this to tests but i would say that following on from our recent discussion you are correct in that if no IP traffic has been sent between the switches then i would not expect to see an entry for sw2 on sw1.
Furthermore i would expect in the CEF adjacency table on both sw1 and sw2 to see a glean adjacency for the 199.199.199.0/24 subnet.
Jon
Thanks Jon!
How about punt adjacency?
My reasoning is since no mac -address is present,therefore packet is punted to layer 3 engine.The reason for punt adjacency in our case could be:
no-adj,no-encap.
However I am not sure which one i.e no-adj or no-encap.
Sarah
As i said i think it will be punted to the CPU but i think the adjacency would show as a glean adjacency in the adjacency table.
I would expect it to be no-adj.
Jon
Edison Ortiz
Sarah,
Correct
Rack1SW1#
Rack9Pod1>2
Rack9Pod1>1
Thanks Edison !
It means entries in Fib are not only sourced from routing table,but also from packets received by a switch. For example entry for 199.199.199.199.2/32 was built in fib after the sw1 received ping from sw2.
thanks a lot Edison and Jon !
HTH,
__
Edison.
Thanks Edison!
