multilink cable on a 1721 router
Need to confirm that this router is cable of multilink bonding. It needs to handle 3 megs, 2 T1's. Below is the Show Ver. I think it only has one serial Interface for now. so we will need to purchase a wic card.
Other then that, can i handle what I want it to do??
LMH_INTERNET#show ver
IOS (tm) C1700 Software (C1700-Y-M), Version 12.2(4)YA2, EARLY DEPLOYMENT RELEAS
E SOFTWARE (fc1)
Synched to technology version 12.2(5.4)T
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Thu 11-Apr-02 21:54 by ealyon
Image text-base: 0x80008124, data-base: 0x807976DC
ROM: System Bootstrap, Version 12.2(7r)XM1, RELEASE SOFTWARE (fc1)
ROM: C1700 Software (C1700-Y-M), Version 12.2(4)YA2, EARLY DEPLOYMENT RELEASE SO
FTWARE (fc1)
LMH_INTERNET uptime is 1 week, 6 days, 14 hours, 50 minutes
System image file is "flash:c1700-y-mz.122-4.YA2.bin"
cisco 1721 (MPC860P) processor (revision 0x100) with 29492K/3276K bytes of memor
y.
Processor board ID FOC07040L4X (645507299), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial(sync/async) network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
1 ACCEPTED SOLUTION
Silver
Re: multilink cable on a 1721 router
You need for T1 card or 2 MFT-WIC card. it will support bith t1.
and already you have one excisting.
You can do multilink PPP...
Dharmesh Purohit
1 REPLY
Silver
Dharmesh Purohit
106
