12-21-2007 10:00 AM - edited 03-03-2019 08:01 PM
What's the maximum number of T1s that can be aggregated into a multilink on a 7609?
I have a client that wants to bundle two bundles of 8T1s together. Is this possible? If yes, what is the configuration?
-Vev
12-21-2007 12:37 PM
I cannot find a hard number, but the cli will let you specify 255 as the maximum number of links on the mlppp interface.
As for the setup, just do it like a normal mlppp setup,
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00804a40f9.html
12-28-2007 07:02 AM
Thanks for the help. This doesn't exactly answer the question, but it does help. I'll try it out to see if the router will take 16 T1s.
12-21-2007 12:43 PM
Which exact hardware do you have? The common limit is 12 links per bundle.
