12-19-2006 08:02 PM - edited 03-03-2019 03:06 PM
Is it advisable to multilink a full T1 and fractional (1/2) T1? Are there any issues with this configuration we should be aware of? Thank you.
Solved! Go to Solution.
12-20-2006 03:32 AM
Hi Friend,
I had raised a similar query with TAC. You can definitely run multilink over different bandwidth links..
Have a look at the last TAC comment on the following post
Narayan
12-19-2006 10:09 PM
Hi Lori
AFAIK its better to use multilink bundle with the links which has same characteristics.
You can get better results if you bundle 2 links with same bandwidth available..
regds
12-20-2006 03:32 AM
Hi Friend,
Narayan
12-20-2006 04:37 AM
Thank you both.
The comments from TAC are exactly what I was looking for.
