Community Member
Multilink Full and Fractional T1?
Is it advisable to multilink a full T1 and fractional (1/2) T1? Are there any issues with this configuration we should be aware of? Thank you.
1 ACCEPTED SOLUTION
Re: Multilink Full and Fractional T1?
Hi Friend,
I had raised a similar query with TAC. You can definitely run multilink over different bandwidth links..
Have a look at the last TAC comment on the following post
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=WAN%2C%20Routing%20and%20Switching&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddc720b
Narayan
Hi Lori
AFAIK its better to use multilink bundle with the links which has same characteristics.
You can get better results if you bundle 2 links with same bandwidth available..
regds
Hi Friend,
Narayan
Community Member
Thank you both.
The comments from TAC are exactly what I was looking for.
152
