Multilink input errors
Jason Jayko
Our cisco 1841 router has been pulling alot of input errors for the last month on the multilink. No other errors. I've restarted the router switched the t's arround same thing, constant errors. Have even removed and rebuilt the multilink and tried another t1 controller card with no luck. Our t1 provided has test the lines clean.
System image file is "flash:c1841-advsecurityk9-mz.124-16.bin"
Cisco 1841 (revision 7.0) with 233472K/28672K bytes of memory.
Processor board ID FTX1126W1GR
2 FastEthernet interfaces
3 Serial interfaces
2 Channelized T1/PRI ports
1 Virtual Private Network (VPN) Module
WIC T1-DSU
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
8 Replies 8
Jason Jayko
  MTU 1500 bytes, BW 3072 Kbit, DLY 100000 usec,
     reliability 128/255, txload 1/255, rxload 1/255
  Encapsulation PPP, LCP Open, multilink Open
  Open: IPCP, loopback not set
  Keepalive set (10 sec)
  DTR is pulsed for 2 seconds on reset
  Last input 00:00:00, output never, output hang never
  Last clearing of "show interface" counters 00:09:26
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 7601
  Queueing strategy: fifo
  Output queue: 40/40 (size/max)
  5 minute input rate 10000 bits/sec, 15 packets/sec
     7504 packets input, 578290 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     7504 input errors, 0 CRC, 7504 frame, 0 overrun, 0 ignored, 0 abort
     36 packets output, 8726 bytes, 0 underruns
     0 carrier transitions
Hello Jason,
Is the above output taken from the multilink or physical member? If the above output belongs to multilink then you need to check all the member interfaces for errors. Figure out the interface which is giving error & remove that interface from the multilink & check. Normally this could be becoz of bad cable or interface
HTH,
-bava-
Serial0/1/0:1 is up, line protocol is up
  Hardware is GT96K Serial
  Description: .02
  MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
     reliability 255/255, txload 12/255, rxload 3/255
  Link is a member of Multilink bundle Multilink1, loopback not set
  Last input 00:00:00, output 00:00:03, output hang never
  Last clearing of "show interface" counters 00:01:40
  Output queue: 0/40 (size/max)
  5 minute input rate 23000 bits/sec, 20 packets/sec
  5 minute output rate 74000 bits/sec, 28 packets/sec
     4603 packets input, 778970 bytes, 0 no buffer
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     8151 packets output, 2939869 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     1 carrier transitions
  Timeslot(s) Used:1-24, SCC: 0, Transmitter delay is 0 flags
Serial0/1/1:1 is up, line protocol is up
  Description: .01
     reliability 255/255, txload 12/255, rxload 4/255
  Last clearing of "show interface" counters 00:01:41
  5 minute input rate 25000 bits/sec, 20 packets/sec
     4624 packets input, 791671 bytes, 0 no buffer
     8188 packets output, 2957000 bytes, 0 underruns
  Timeslot(s) Used:1-24, SCC: 1, Transmitter delay is 0 flags
These interfaces seems to be good. Can you share the multilink config & output??
controller T1 0/1/0
framing esf
linecode b8zs
channel-group 1 timeslots 1-24
controller T1 0/1/1
framing esf
linecode b8zs
interface Multilink1
ip address 63.148.39.250 255.255.255.252
ip route-cache flow
no cdp enable
ppp multilink
ppp multilink group 1
interface Serial0/1/0:1
description .02
no ip address
encapsulation ppp
no fair-queue
ppp multilink
interface Serial0/1/1:1
description .01
no ip address
encapsulation ppp
no fair-queue
ppp multilink
Multilink1 is up, line protocol is up
  Hardware is multilink group interface
  Internet address is 63.148.39.250/30
     reliability 138/255, txload 1/255, rxload 1/255
  Last input 14:22:28, output never, output hang never
  Last clearing of "show interface" counters 22:27:14
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 3145
  5 minute input rate 15000 bits/sec, 8 packets/sec
  5 minute output rate 22000 bits/sec, 9 packets/sec
     6928368 packets input, 1405995543 bytes, 0 no buffer
     6928364 input errors, 0 CRC, 6928364 frame, 0 overrun, 0 ignored, 0 abort
     7547944 packets output, 3281138402 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
config is okay. can you check the show ppp multilink output & see everything is ok??
Multilink1, bundle name is alb-priv-10
  Endpoint discriminator is alb-priv-10
  Bundle up for 22:47:36, total bandwidth 3072, load 1/255
  Receive buffer limit 24000 bytes, frag timeout 1000 ms
    0/0 fragments/bytes in reassembly list
    0 lost fragments, 935471 reordered
    0/0 discarded fragments/bytes, 0 lost received
    0x79F98B received sequence, 0xBA0E60 sent sequence
  Member links: 2 active, 1 inactive (max not set, min not set)
    Se0/1/1:1, since 22:47:36
    Se0/1/0:1, since 22:47:36
    Se0/0/0 (inactive)
No inactive multilink interfaces
