Multilink PPP
Hi folks -
I am planning to bundle 6 T1's together using Multilink PPP on a Cisco 2821 router. For that, I plan to order 3 dual
WIC's for terminating the 6T1's.
That being said, how is the traffic load balanced over the 6T1's? If the load balancing happens, is it per packet or per destination. The router will have CEF enabled.
All the 6T1's are from the same provider.
Thanks!
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Multilink PPP
Hello Kunal,
>> So if a router has to transmit a 100 MB file across a WAN using the 6T1's bundle, and assuming there is no traffic on the bundle, will the 100MB file fragments be sent over the first T1 alone or will the packets be evenly distributed over the 6 T1's?
evenly distributed over member links using a round robin algorithm eventually fragmented with each fragment sent on a different member link.
This is one of the reasons for using multilink ppp
Hope to help
Giuseppe
Re: Multilink PPP
On a Multilink bundled it is only per packet by default and by RFC also.
http://www.faqs.org/rfcs/rfc1717.html
GK
Re: Multilink PPP
you can check the below link also, how packets are handled on the multilink interfaces
http://www.cisco.com/en/US/tech/tk713/tk507/technologies_tech_note09186a008009408f.shtml
hope this helps you,
GK
Super Bronze
Re: Multilink PPP
"That being said, how is the traffic load balanced over the 6T1's? If the load balancing happens, is it per packet or per destination. The router will have CEF enabled. "
If you place all the links into a MLPPP bundle, the router will only "see" one link. I.e. L3 load balancing isn't an issue.
MLPPP as it receives packets, should (ideally) send a packet on the first physically available link. Optionally, MLPPP can fragment a packet and send fragments across all physical links.
Packets can arrive out of sequence on the receiving side, and/or MLPPP fragmented, but MLPPP receiver will reconstruct flow before forwarding.
Re: Multilink PPP
What configuration do I need for this?
"Optionally, MLPPP can fragment a packet and send fragments across all physical links".
Re: Multilink PPP
Hello Kunal,
Hope to help
Giuseppe
172
