Webcast-Catalyst9k
Multilink Question
Here is the configuration.
interface multilink 1
ip address 192.168.249.101 255.255.255.252
encapsulation ppp
no peer neighbor-route
no cdp enable
bandwidth 3000
ppp multilink fragment disable
ppp multilink group 1
ppp multilink links minimum 2 mandatory
no shut
ip flow ingress
ip flow egress
ip route-cache flow
exit
int Serial0/2/0:1
no shut
encapsulation ppp
ppp multilink
no ip address
keepalive
ip flow ingress
ip flow egress
ip route-cache flow
exit
int Serial0/2/1:1
no shut
encapsulation ppp
ppp multilink
no ip address
keepalive
ip flow ingress
ip flow egress
ip route-cache flow
exit
Here my questons.
1. do we need the netflow statements on serial ports or just the multilink interfaces for sites with multi circuits?
2. What is "ppp multilink links minimum 2 mandatory" for? Is it necessary to configure it?
1 REPLY
Re: Multilink Question
1. Netflow only goes on the Multilink interface (layer 3 interfaces).
2. ROUTER(config-if)#ppp multilink links minimum 2 ?
mandatory Disable network layer until minimum number of links is reached
The layer 3 interface will not be functional until there are at least two T1's up. It is not necessary, just an option.
Hope that helps.
131
