05-27-2008 11:29 AM - edited 03-03-2019 10:07 PM
I would like to know if is it possible to us config multiple instances under a single OSPF process.
I mean, config multiple instances of OSPF routing over single OSPF process like the command "instance" for OSPF v3.
We know that using the VRF we can reach this task but, without using it, is it possible or has it any specific command on OSPFv2 to reach this task?.
Marcelo
05-27-2008 11:34 AM
Marcelo
I do not think that it is possible to configure multiple instances of OSPF under a single process in OSPFv2.
Rick
06-04-2008 06:53 AM
Hello Rick,
Ok, thanks for your information.
Att.,
Marcelo
06-04-2008 07:32 AM
Well! i`m not sure abt the question u`v asked as one can have multiple OSPF instances by having multiple OSPF processes on the same router. But your question is having multiple OSPF instaces under the same process. Not sure how correct is that.
Plz Correct me if i`m wrong.
Raees.
06-04-2008 07:41 AM
Hi Raees,
The second statement of your response is right: my doubts is about "multiple OSPF instances under the same process".
Att.,
Marcelo
