01-09-2012 12:28 PM - edited 03-05-2019 06:46 AM
I have only seen this problem with several video conferences from one location. Currently there is only one T1 connection from our HQ to remote location. When two conference calls are set to use 256Kbps connection to come back to the main HQ, after an hour or so the T1 connection would drop. What I mean about drop is that the route on the 2911 will disappear. I have to wait about 10 minutes for the connection to come back up or I have to reboot the router for the connection to appear again. There are no interface drops on the serial connections or ethernet connections.
HQ - 2911
Remote - 1821
2911 running config:
Current configuration : 3529 bytes
version 15.0
service timestamps log datetime msec localtime show-timezone year
service password-encryption
hostname
boot-start-marker
boot-end-marker
card type t1 0 0
card type t1 0 1
card type t1 0 2
no aaa new-model
clock timezone gmt -5
clock summer-time cdt recurring
no network-clock-participate wic 0
no network-clock-participate wic 1
no network-clock-participate wic 2
no ipv6 cef
ip source-route
ip cef
license udi pid CISCO2911/K9 sn FTX1513ALLS
controller T1 0/0/0
cablelength long 0db
channel-group 0 timeslots 1-24
controller T1 0/0/1
clock source internal
controller T1 0/1/0
channel-group 3 timeslots 1-24
controller T1 0/1/1
channel-group 2 timeslots 1-24
controller T1 0/2/0
controller T1 0/2/1
buffers middle permanent 200
buffers middle max-free 230
buffers middle min-free 50
buffers big permanent 75
buffers big max-free 200
buffers big min-free 15
buffers verybig permanent 20
buffers verybig max-free 20
buffers tune automatic
interface Multilink1
ip address 192.168.200.1 255.255.255.252
ip flow ingress
ip flow egress
load-interval 30
ppp multilink
ppp multilink group 1
ppp multilink fragment disable
no cdp enable
hold-queue 4000 out
interface GigabitEthernet0/0
ip address 10.10.3.1 255.255.240.0
ip flow ingress
ip flow egress
duplex full
speed auto
no cdp enable
hold-queue 3000 in
hold-queue 4096 out
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:0
no ip address
encapsulation ppp
ppp multilink
no fair-queue
hold-queue 40 out
interface Serial0/0/1:0
no ip address
encapsulation ppp
ppp multilink
no fair-queue
hold-queue 40 out
interface Serial0/1/0:3
ip address 192.168.1.2 255.255.255.0
ip flow ingress
ip flow egress
load-interval 60
no fair-queue
hold-queue 200 in
hold-queue 4000 out
interface Serial0/1/1:2
ip address 192.168.8.2 255.255.255.0
ip flow ingress
ip flow egress
load-interval 30
no fair-queue
hold-queue 200 in
hold-queue 4096 out
interface Serial0/2/0:0
no ip address
encapsulation ppp
ppp multilink
no fair-queue
interface Serial0/2/1:0
no ip address
encapsulation ppp
ppp multilink
no fair-queue
ip forward-protocol nd
no ip http server
no ip http secure-server
ip flow-cache timeout active 1
ip flow-export source GigabitEthernet0/0
ip flow-export version 5
ip flow-export destination
ip route 0.0.0.0 0.0.0.0 10.10.18.1
ip route 10.10.1.0 255.255.255.0 192.168.1.1
ip route 10.10.5.0 255.255.255.0 192.168.8.1
ip route 10.10.9.0 255.255.254.0 192.168.200.2
logging trap notifications
logging
snmp-server community
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
session-timeout 60
privilege level 15
logging synchronous
login
transport input telnet
scheduler allocate 20000 1000
end
01-09-2012 02:19 PM
Update IOS and try again.
01-10-2012 09:49 AM
Dumb question, but which IOS would I need...currently the IOS installed on the 2911 is:
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.0(1)M4
What is listed on the IOS download is this:
01-10-2012 10:16 AM
Suggest 15.0(1)M7
If it still happens, take some show ip route to prove your observation.
01-10-2012 10:19 AM
Would I just download the Universial and not the Universal - No Payload Encryption?
01-10-2012 11:18 AM
Ok, when I also do a sh flash command, I notice:
2911#sh flash
-#- --length-- -----date/time------ path
1 62682268 Mar 25 2011 18:52:20 c2900-universalk9-mz.SPA.150-1.M4.bin
2 2903 Mar 25 2011 19:02:08 cpconfig-29xx.cfg
3 2941440 Mar 25 2011 19:02:22 cpexpress.tar
4 1038 Mar 25 2011 19:02:30 home.shtml
5 115712 Mar 25 2011 19:02:38 home.tar
6 1697952 Mar 25 2011 19:02:50 securedesktop-ios-3.1.1.45-k9.pkg
7 415956 Mar 25 2011 19:03:04 sslclient-win-1.1.4.176.pkg
If I run the "erase flash" command, will all of these packages get deleted? If so, can someone point me to the documentation on the correct command to run before running copy tftp flash?
01-10-2012 11:32 AM
This link prvides the IOS upgarde procedure for 2900 series IOS15.0:
I hope it works for you, the original link required partner login and I do not know if you have that.
Anyway, that link is:
regards,
Leo
01-10-2012 01:17 PM
If you never did an IOS update before, and/or never did network troubleshooting, configuration, etc. I strongly recommend you hire a reputable professional for the task.
01-10-2012 03:34 PM
No need to hire anyone . I was able to do the IOS upgrade on another 2911 I have for another purpose. It was straight forward after saving the old IOS config and running/startup configs. Kept the M4 bin in flash/flash0 and rebooted with the M7 flash. I will do the router with the issue Thursday and test/post results of the video conferencing.
