Multiple VLAN inside the same subnet
Is this possible on Cisco 3750 switches?
ip proxy-arp
interface ve 2
ip address 192.168.2.1 255.255.255.0
interface ve 3
ip follow ve 2
interface ve 4
ip follow ve 2
Check this article:
http://gcharriere.com/blog/?p=620
What would the commands to do this in IOS look like?
Re: Multiple VLAN inside the same subnet
Why do you need to do this? I dont believe this is applicable with interface vlan,
Sometimes for point to point connection we use ip un number, but for interface vlan i dont think this will be a good idea
Thanks for reply.
I want this to fix some design problems, and separate clients.
This will save me a lot og work and time, time I do not have
Silver
By splitting the broadcast domain in Brocade style separation would be restricted to broadcasts, multicasts and unknown unicasts but IP connectivity would be still unrestricted. What would you benefit from splitting up? Today's CPUs can easily handle 1000 hosts' broadcast packets.
However, if you introduce private VLANs, you can control and restrict host-to-host traffic and create groups separated from each other.
Silver
Brocade's method is not available on Cisco because IP Proxy ARP requires an IP address on the interface.
528
