I have NEW AT&T PNT MPLS Network with 10 remote sites.
The entire network will be running BGP.
All remote CE locations will have different ASN's.
I have 2 of my locations that have internet connections. CE1 and CE2
I want to be able to send half of my locations internet traffic to CE1 and the rest of the locations out the internet at CE2. Is their a way to do this with BGP being that the AT&T MPLS cloud will have 2 default routes injected into it?
I know I can control the default route selection on the PE by priority by using the community list and lowering the the preference for back up purposes, but I am at a loss with how to control it with seperate remote locations wanting to use sepererate default routes in the MPLS cloud.
I know that I can use a GRE TUNNEL for half of the locations and route them across the MPLS but failover is little unstable in that solution in that the a GRE Tunnel will not always go down.
I was wanting to know if there is a BGP option to control the route selection inside the MPLS cloud or at CE?
If GRE is the only way to go then is there a way to control the route across the GRE to make sure that it will go down if the tunnel goes down.
I currently do not have any configurations since the MPLS cloud is just now being provisioned.
I am wondering has anyone else run into this siutation and is their a workaround or some mechanism inside BGP that I can make this work?
IDEAS ????????
