Mutual redistribution between EIGRP and BGP
rvr_76bg
Hello guys,
I need to redistribute BGP into EIGRP and vise versa. I did it in my lab and seems like I am seeing EIGRP routes in the BGP table but I don’t see BGP routes in my EIGRP table.
Can anybody provide some info about that kind of redistribution? I already have redistributed OSPF and BGP in the same way in my production network and I didn’t face this problem. Also, I researched Internet and I couldn’t find clear example (a doc) with mutual redistribution between BGP in EIGRP and vise versa. Is it straight forward like OSPF and BGP and I am missing something or there is a tricky part that I don’t know about.
Here is my topology:
R1===R2===R3===R4===R5
R1 is EIGRP speaker only with R2
R2 is speaking EIGRP to R1 and EBGP to R3
R3 is speaking EBGP to both – R2 and R4
R4 is speaking EIGRP to R5 and EBGP to R3
R5 is speaking EIGRP only with R4
I don’t see EIGRP routes coming from R5 on R1 and vise versa
However I see them on all BGP only routers (R2,R3,R4), seems like BGP doesn’t redistribute into EIGRP its routes by some reason.
I configured a loopback interface on R3 and advertized the IP add with network command in BGP and I see this route on both EIGRP routers (R1,R5).
Probably I am missing something. Please help… would you please point me to a doc with an example?
Thank you in advance!
Gregory Camp
Did you set a default metric when you configured redistribute bgp X under router eigrp?
5 Replies 5
Gregory Camp
So, that was the problem. I cleared the configs and started from s
cratch. What I was missing is default-metrin under router eigrp x.
Thank you very much!
rvr
vishwancc
Level 3
Level 3
Hi ,
Could you share the configuration related to redistribution.
Do you see routes in the EIGRP topology table.
Chao
Vishwa
I agree with Gregory, you should indicate the EIGRP metric to use for BGP redistributed routes into router eigrp section. Using a route-map would be a good solution.
Regards.
Are you having metrics for bgp under your eigrp process?
Have it something like this
router eigrp x
redistribute bgp metric xxxx xxx xxx x xxxx
Best Regards,
Christopher
