Community Member
MWR 1941-DC ROUTER
Dear,
I have ten MWR 1941-DC router.I am using these router for E1 link. But I am facing link trouble( this router is configured redudency--y cable).
Can you tell whether these router is feasible for E1 link ( data connectivity)or not?
1 REPLY
Re: MWR 1941-DC ROUTER
The MWR-1941 supports E1 and the links should be working. What problem are you seeing with the links? Are you using the required y-cable available from Anixter? Is the E1 a service provider circuit? If so, make sure that the E1 is configured properly on the MWR to match the carrier.
197
