My Router doenst rounting...
Dear, All
I have a 2620 router encapsulated by frame-relay. By the console I can ping everything but I cant ping the internet throught Ethernet interface, in other words... My local Area connection doenst access the Internet.. What can I do? Tks!!
Re: My Router doenst rounting...
Hi Danil,
Can you confirm if from any workstation on your lan can you ping you router lan interface or not?
If yes then can you ping your router wan interface or not?
Have you done natting on your router? If this is the internet router and your lan ip is not getting natted before it leaves the router you will not get the ping reply.
Please update more about the router cofig. If this is the internet router and if your lan is getting natted or not.
Ankur
Ankur,
My lan pings my router lan interface but it doenst ping my wan interface.
This router is my new internet router....
Hi Dan,
Can you pleas epost the output of sh run and sh ip route?
Ankur
103
