NAM Modules
I have a 6500 L3 supevisor module and I am trying to access the NAM module in one of the slots. The session command does not work. Does anyone know the service command that allows access to the NAM module so I can configure it. This is rather urgent...need before 12:00 midnight if possible. Thanks
Re: NAM Modules
You can session into the NAM by isuing the following command "session X processor 1" command. Just replace X with the slot number the NAM is installed.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Config_Notes/78_10406.html#wp115156
HTH,
Mark
Re: NAM Modules
i have two 6513 chasis configured in VSS Mode.I have two NAM modules in both the switches.I want to know what will be the status of NAM module in standby switch.
Regds
Nehal Modi
Re: NAM Modules
if possible.  Thanks
Check out the below link for establish session with NAM
http://www.cisco.com/en/US/docs/net_mgmt/network_analysis_module_software/3.4/catalyst_6000/quick/guide/qsg.html
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
219
