NAT a single address across WAN
iholdings
Greetings,
I need to NAT a single IP address from network A across the WAN to network B using two routers attached to a T1. Example - IP:10.1.5.47 on NetA becomes IP:172.16.10.79 on NetB.
Network B is also the default Internet gateway for network A. Is this simple to do? Thanks.
2 Accepted Solutions
Yes, it will only NAT that one IP address, all other traffic will not get Natted.
Jon
put the nat statement on your netb router:
ip nat inside source static 10.1.5.47 172.16.10.79
interface FastEthernet1/0
ip nat out
interface Serial2/0:0
ip nat in
remove the nat statement on NetA.
that should do it.
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
15 Replies 15
Jon Marshall
On router connected to network A
int fa0/0
ip nat inside
int fa0/1
ip nat outside
where fa0/0 is the interface connecting to the internal network A and fa0/1 is the interface connecting this router to the router with network B on it.
Jon
Thanks for the prompt reply Jon.
So ... this will only NAT the single IP address coming from NetA and not all IPs correct? Forgive my ignorance.
Jon
Jon,
Thought this work serve my needs - but I've been told the user can't see past the internal netA
Here's what I have on the NetA router:
interface Ethernet0/0 [interface to NetB]
description BRIDGE connection to FOX 7206 - Fast4/0
ip address 10.1.51.2 255.255.255.252
no ip directed-broadcast
ip nat outside
ip route-cache flow
interface FastEthernet2/0 [NetA interface]
description LAN interface
ip address 10.1.7.1 255.255.252.0
ip nat inside
ip route-cache flow
full-duplex
any idea why this wouldn't work per your suggestions?
Can you post a "sh ip nat translations" from the router.
the 10.1.5.47 is entering the router in the fa2/0 interface ?
Also does the router at the far end know how to route back to 172.16.10.79 ?
Jon
do the devices on the other side of NetB have a route to 172.16.10.79? you got a visio of the network?
-brad
http://www.ccbootcamp.com
Hi Brad
The devices on NetB don't need a route to 10.1.5.47 as this will have been Natted to 172.16.10.79.
Jon
lol...you replied too quickly. :)
-b
I know, and now my post looks like i'm losing my marbles if anybody else reads it :)
Jon
Hi all. Thanks for taking up my cause.
Here is a simple drawing of the networks. The two networks use EIGRP to route between. The router listed on the inside network - NetB (172.16.10.200) is where the host with 10.1.5.47 needs to get to - but that router only accepts connections from hosts in the 172.16.10.0 subnet - hence the need for the NAT.
Here is the output from your request:
COPA_WAN#sho ip nat translations
Pro Inside global Inside local--- 172.16.10.79 10.1.5.47
and the Outside global and Outside local are blank.
Let me know if you need more data.
Thanks.
sorry - forgot the attachment
so you are trying to have an address on NetA router show up on NetB with using an ip address from the NetB ip subnet? That won't work. If you want to do something like that, you'd have to setup a bridge or setup NAT on the NetB side router, not the NetA side router.
show us your configs for both routers. i'll reply with the config you need on NetB side router.
-brad
Here they are. Thanks again for all of your help!!
ip nat out
ip nat in
that should do it.
-brad
www.ccbootcamp.com
