NAT Advice
Can anyone suggest a sample configuration here?
I want to hide 3 servers behind a 192.168.x.x address so that the SP sees the host addresses coming from that range.
The hosts initite connections to hosts on the SP network, so reachability should be end to end!
The configuration will be applied to EX1.
Help well rated.
Gav
1 REPLY
Re: NAT Advice
you would require static NATs in place
ip nat inside source static 10.22.148.153 192.168.x.x
ip nat inside source static 10.22.148.170 192.168.x.x
ip nat inside source static 10.22.148.171 192.168.x.x
interface
ip nat inside
interface outside
ip nat outside
The only problem is you are asking to hide the servers behind a private address range ans hence may not be accessible from internet if the packets are not converted to a valid public address before they hit the internet
HTH, rate if it does
Narayan
107
