NAT and address efficiency
What would be the most efficient way to use two separate NAT's from a /26 block of addresses and keep the remaining block in intact for the future ?
I have a need to NAT two hosts, one to one, on two separate private lines. One NAT on each separate access. One access is a single router and T1. The other access is dual T1 dual router (2811).
I have a /26 block of addressing from which to draw the requisite addresses.
  • WAN Routing and Switching
1 REPLY
Purple
Re: NAT and address efficiency
Are both of the links from the same ISP ? If that is the case, you would have to split up the /26 into two /27s so that the ISP can route each block down a different link. The reason you need to do this is so that your return traffic travels over the same link as your outbound traffic.
Pls do remember to rate posts.
Paresh
83
