NAT and no NAT 1800
I have a 1800 router setup with public IP on the outside FE0 and private address on VLAN1 on the inside.
Internet GW
195.171.195.1/24
1800
FE0
195.171.195.2/24
ip nat outside
VLAN1 (FE1)
10.100.1.0/24
ip nat inside
Let say I want to use address
195.171.195.3 plugged into one of the switch port on the back of 1800 in FE3. I don't want to NAT outside inside on this port I just want this address to route out so it appears public. Is this possible without affecting the NAT setup? Obviously I can have the whole router set as no-nat and that works, im not sure if I can get this to co-exist.
1 REPLY
Re: NAT and no NAT 1800
Try
FE0
ip unnumbered int fe1
ip nat outside
FE1
ip add 195.171.195.2/24 secondary
ip add 10.10.1.0/24
ip nat inside
Hope this helps.
If helpful...pls rate.
JD
167
