NAT and Routed Network with Two ISP's on one router
I'm sure this has been done covered many times, but I am not finding it.
I have two ISP connections.
With ISP-A I have a /30 between us and 200.100.100.0/24 is routed to me via the /30 for thsi example we will say the /30 is 1.1.1.1 on isp end and 1.1.1.2 on my end
With ISP-B I have a 100.0.0.0/29 subnet. and the ISP gateway is on that subnet at 100.0.0.1
On the inside of my network I have devices using both 200.100.100.x addresses and devices on 192.168.100.x that need to use NAT.
I would like all of the devices on 200.100.100.x addresses to continue using ISP-A as their gateway.
Everything on 192.168.100.x should use NAT and go out ISP-B
I have tried
ip nat inside source route-map ISP-A interface GigabitEthernet0/1 overload
route-map ISP-A permit 10
 match ip address 101
 match interface GigabitEthernet0/1
 set ip next-hop 100.0.0.1
 match ip address 111
 match interface Multilink1
 set ip next-hop 1.1.1.1
The problem comes when I have default routes to ISP-A in the router than none of the ISP-B traffic works, and vice versa.
36
