Guys,
I have a 2801 with 2 Fastethernet ports. Each one goes to a seperate IP segment. Currently, I can VPN into router and get to both IP segments. The IP segment on 192.168.253.x does not have ip nat inside, if I do enable that, I can no longer access that segment thru VPN. The other side, 10.247.1.x does have ip nat inside and can acces thru VPN. Attched is config without the ip nat inside statement on FE0/0...what do I need to do to use same outside IP for NAT and be able to VPN into both segments.
Thanks.
