Webcast-Catalyst9k
NAT doesn't work in 831 router
We just added another XP computer to our network and would like to access it using Remote Desktop from the Intrenet. So, we added this line in the Cisco 831 router.
ip nat outside source static tcp x.x.x.70 3389 172.16.5.2 3389 extendable
But the user can?t access it using the RDP. We can access the XP internally. What?s wrong with the Cisco router configuration?
version 12.3
no service pad
service password-encryption
hostname 831
clock timezone America/Chicago -6
clock summer-time America/Chicago date Apr 6 2003 2:00 Oct 26 2003 2:00
no aaa new-model
ip subnet-zero
no ip source-route
ip domain name cisco.com
ip name-server 4.x.x.1
ip dhcp excluded-address 172.16.5.1 172.16.5.9
ip dhcp excluded-address 172.16.5.51 172.16.5.254
ip dhcp pool sdm-pool1
network 172.16.5.0 255.255.255.0
default-router 172.16.5.1
dns-server 4.2.2.1
no ip bootp server
ip inspect name sdm_ins_in_100 cuseeme
ip inspect name sdm_ins_in_100 ftp
ip inspect name sdm_ins_in_100 h323
ip inspect name sdm_ins_in_100 netshow
ip inspect name sdm_ins_in_100 rcmd
ip inspect name sdm_ins_in_100 realaudio
ip inspect name sdm_ins_in_100 rtsp
ip inspect name sdm_ins_in_100 smtp
ip inspect name sdm_ins_in_100 sqlnet
ip inspect name sdm_ins_in_100 streamworks
ip inspect name sdm_ins_in_100 tftp
ip inspect name sdm_ins_in_100 tcp
ip inspect name sdm_ins_in_100 udp
ip inspect name sdm_ins_in_100 vdolive
ip inspect name sdm_ins_in_100 icmp
ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
interface Ethernet0
description $FW_INSIDE$$ETH-LAN$
ip address 172.16.5.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
no cdp enable
interface Ethernet1
description $FW_OUTSIDE$$ETH-WAN$
ip address x.x.x.70 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip inspect sdm_ins_in_100 in
duplex auto
no cdp enable
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
ip nat inside source list 1 interface Ethernet1 overload
ip nat outside source static tcp x.x.x.70 3389 172.16.5.11 3389 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 x.x.x.1 permanent
ip http server
ip http authentication local
ip http secure-server
access-list 1 permit 172.0.0.0 0.255.255.255
no cdp run
banner login ^CCAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
1 ACCEPTED SOLUTION
Silver
Re: NAT doesn't work in 831 router
You have mapped the RDP protocol to two inside local hosts. This is not possible in case of a single outside global address.
NAT only allows one port address translation per host.
--Leon
* Please rate posts.
Silver
--Leon
Sorry, it should be x.x.x.71 as showing below.
ip nat outside source static tcp x.x.x.71 3389 172.16.5.2 3389 extendable
x.x.x.70 works but x.x.x.71.
I fixed it using this line:
ip nat inside source static tcp 172.16.5.2 3389 xx.xx.xx.71 3389 extendable
The details can be found here. http://www.chicagotech.net/cisco/381nat1.htm
180
