NAT explanation
ip nat inside source static tcp 10.0.0.3 80 86.96.201.7 80 extendable
Everyone's tags (6)
NAT explanation
what does this command do? Thanks
NAT explanation
It will translate the packet arrived on
              a) outside interface with the destination IP 86.96.201.7 port 80/TCP to inside 10.0.0.3 port 80/TCP.
              b) inside interface with the source IP 10.0.0.3 port 80/TCP that has as destination interface outside
You are NATing the inside host. Extendable will allow you to use more the one static pat (port address translation ) with the same public ip.
Dan
NAT explanation
ip nat inside source static 10.5.50.9 89.144.102.179
is ther any difference between this command and above-mentioned command ?
NAT explanation
Yes.
This will allow you to
               - use the public ip only for this translation
               - translate any traffic from and to the inside host ( 10.5.50.9 ) to the public ip
Dan
NAT explanation
Hello Dan,
Correct me please if I am wrong here but in this case:
the extendable keyword actually does nothing, as this translation is already fully specified by addresses, protocols and ports. The extendable keyword was more used with plain IP-to-IP translation and to be completely honest, to this day I have not fully understood its usage.
Best regards,
Peter
NAT explanation
Hi Peter,
My understanding about the extendable option is that allows you to do PAT using the same outside global.
I do now that this option is available also on ip-ip and network-network static nat...but I do not see how could you apply the extandable in those cases ( ip-ip and net-net ).
I've done a quick test :
interface FastEthernet0/0
ip address 1.1.1.1 255.255.255.0
ip nat inside
ip virtual-reassembly
end
interface Loopback0
ip address 2.2.2.2 255.255.255.0
ip nat outside
end
ip route 10.10.10.0 255.255.255.0 1.1.1.254
Commands :
R1(config)#ip nat inside source static tcp 10.10.10.10 80 2.2.2.10 80
R1(config)#ip nat inside source static tcp 10.10.10.11 81 2.2.2.10 81
R1(config)#
R1(config)#^Z
R1#sh run | i nat
ip nat outside
ip nat inside
ip nat inside source static tcp 10.10.10.10 80 2.2.2.10 80 extendable
ip nat inside source static tcp 10.10.10.11 81 2.2.2.10 81 extendable
R1#
The extendable keywork was automatically added.
I opened the NAT overview :
"The extendable keyword allows the user to configure several ambiguous static translations, where an ambiguous translations are translations with the same local or global address."
http://www.cisco.com/en/US/technologies/tk648/tk361/tk438/technologies_white_paper09186a0080091cb9.html
Dan
NAT explanation
hie;
Guys i have a 2911 Router with 3 interfaces (GIG) and 4 wic 10/100 which is connected to my lan and the 3 interfaces are connected to 3 ISP i want the correct NAT and Access-list to send emails from my mail server on 192.168.0.1 using ISP 3 who is on Gig0/2
5515
