Webcast-Catalyst9k
NAT for local originated packet
I've configured a Cisco 3725 w/ IOS 12.(4)21a to implement  natting for local originated packet going out towards a  specific IP destination
Basically I configured ip nat outside on the egress i/f /(serial 0/0.100)
interface Serial0/0.100 point-point
ip address 172.16.1.1 255.255.255.0
ip nat outside
ip virtual-reassembly
and ip nat inside source list TO-DST interface serial 0/0.100 in global configuration mode
ip access-list extended TO-DST
permit ip host 10.10.10.1 host 172.16.10.3
ip nat inside source list TO-DST interface Serial0/0.100 overload
The C3725 has an entry for 172.16.10.3 in IP RIB and pinging from this router to dst is ok. Now a question arises.....
How can the router perform NAT if ip nat inside command is not configured on any interfaces ?
Silver
Once you have NAT outside defined, all other interfaces are treated as inside for NAT translation.
Thanks.
But....this is a default behaviour ? And why then configure ip nat inside (on the the inside router interface) in a enterprise scenario to perform natting for inside hosts ?
Silver
Not sure. But you have designated a boundary:  an outside interface. And you do have a ip nat inside statement configured on the router.
Thanks.
.....just to better understand...In my scenario I've an outside interface (serial0/0.100 configured with ip nat outside) but I've not configured any inside interface (no interface has ip nat inside configured)
How can NAT work ? Is it a specific condition in which packets (ping) are local originated by the router itself ?
Thanks in advance
Re: NAT for local originated packet
Hi Carlo,
I think that you can solve that, tricking the router
int lo0
ip add 1.1.1.1 255.255.255.255
ip nat inside
route-map NAT-NH-LOOP
match
set ip next-hop 1.1.1.1
ip local policy route-map NAT-NH-LOOP
Dan
Yes, I know this trick (the local (ping) originated packet re-enter from loopback0 where ip nat inside is configured...)....but I do not understand why it works without ip nat inside on any interfaces...
I do not belive that NAT is performned
First do you have any other nat configured ?
Can you post :
debug ip nat
debug ip icmp
ping 172.16.10.3
unde all
Dan
R1#sh run int lo101
Building configuration...
Current configuration : 86 bytes
interface Loopback101
ip address 10.10.10.1 255.255.255.255
ip ospf 1 area 0
end
R1#sh run int s0/0.100
Current configuration : 198 bytes
interface Serial0/0.100 point-to-point
ip nat outside
ip ospf 1 area 0
snmp trap link-status
frame-relay interface-dlci 102
end
R1#sh runn | b access-list
R1#sh run | in nat inside
R1#
R1#
R1#debu ip nat
IP NAT debugging is on
R1#debu ip icmp
ICMP packet debugging is on
R1#
R1#
R1#
R1#sh deb
Generic IP:
R1#
R1#ping 172.16.10.3 source loopback 101 r 2
Sending 2, 100-byte ICMP Echos to 172.16.10.3, timeout is 2 seconds:
Packet sent with a source address of 10.10.10.1
Success rate is 100 percent (2/2), round-trip min/avg/max = 108/122/136 ms
R1#
*Mar  1 00:11:09.623: NAT: s=10.10.10.1->172.16.1.1, d=172.16.10.3 [16]
*Mar  1 00:11:09.751: NAT*: s=172.16.10.3, d=172.16.1.1->10.10.10.1 [16]
*Mar  1 00:11:09.755: ICMP: echo reply rcvd, src 172.16.10.3, dst 10.10.10.1
*Mar  1 00:11:09.759: NAT: s=10.10.10.1->172.16.1.1, d=172.16.10.3 [17]
*Mar  1 00:11:09.863: NAT*: s=172.16.10.3, d=172.16.1.1->10.10.10.1 [17]
*Mar  1 00:11:09.867: ICMP: echo reply rcvd, src 172.16.10.3, dst 10.10.10.1
R1#
R1#u all
All possible debugging has been turned off
R1#
Any help is apreciated..
To my knowledge this is not expected !  Are you using real hardware ? What IOS/HW are you using on this one ?
Dan
Same behaviour (w/o any ip nat inside) on 'real' C7200
7200-RR1#sh ver
Cisco IOS Software, 7200 Software (C7200-ADVENTERPRISEK9-M), Version 12.2(33)SRE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 25-Jan-11 08:35 by prod_rel_team
ROM: System Bootstrap, Version 12.3(4r)T3, RELEASE SOFTWARE (fc1)
7200-RR1 uptime is 7 weeks, 5 days, 11 hours, 15 minutes
System restarted at 10:10:16 MET Mon Jan 23 2012
System image file is "disk2:c7200-adventerprisek9-mz.122-33.SRE3.bin"
Last reload type: Normal Reload
this time the ping source address is 172.16.217.230 (loop0) with destination 172.16.217.15
7200-RR1#debu ip nat
7200-RR1#debu ip icmp
7200-RR1#
7200-RR1#
7200-RR1#sh deb
Generic IP:
7200-RR1#
7200-RR1#ping 172.16.217.15 source loopback 0 repeat 2
Sending 2, 100-byte ICMP Echos to 172.16.217.15, timeout is 2 seconds:
Packet sent with a source address of 172.16.217.230
Success rate is 100 percent (2/2), round-trip min/avg/max = 28/28/28 ms
7200-RR1#
Mar 17 21:30:23.451 MET: NAT: ICMP id=8->1024
Mar 17 21:30:23.451 MET: NAT: s=172.16.217.230->172.16.203.230, d=172.16.217.15 [37]
Mar 17 21:30:23.479 MET: NAT*: ICMP id=1024->8
Mar 17 21:30:23.479 MET: NAT*: s=172.16.217.15, d=172.16.203.230->172.16.217.230 [37]
Mar 17 21:30:23.479 MET: ICMP: echo reply rcvd, src 172.16.217.15, dst 172.16.217.230, topology BASE, dscp 0 topoid 0
Mar 17 21:30:23.479 MET: NAT: ICMP id=8->1024
Mar 17 21:30:23.479 MET: NAT: s=172.16.217.230->172.16.203.230, d=172.16.217.15 [38]
Mar 17 21:30:23.507 MET: NAT*: ICMP id=1024->8
Mar 17 21:30:23.507 MET: NAT*: s=172.16.217.15, d=172.16.203.230->172.16.217.230 [38]
Mar 17 21:30:23.507 MET: ICMP: echo reply rcvd, src 172.16.217.15, dst 172.16.217.230, topology BASE, dscp 0 topoid 0
7200-RR1#
Any idea ? Carlo.
Hi Carlo,
Tested and found the same behavior.
It seams that the router considers the control-plane as an inside interface.
Have a look at this link :
http://ieoc.com/forums/p/18741/161550.aspx
Dan
great explaination !
Another question related to NAT....
Having a router an inside and outside interface configured, the only NAT option supported on outside interface is ip nat ouside source ...... while on inside i/f source/destination natting (ip nat inside source/destination ) is supported
Why these differences exist from a configuration point of view ?
Hi Carlo,
ip nat inside/outside source  list/route-map is for Source NAT and the flow must be initiated from the interface specified in the command - this does not apply for the static command.
ip nat inside/outside source static - is bidirectional - meaning that the packet could be initiated on any interface (inside or outside ) this means that is not only Source NAT but also Destination NAT,
ip nat inside destination is used for loadbalancing, the packet must be initiated from OUTSIDE.
Dan
Hi Dan,
ip nat outside source lis/route-map create a dynamic NAT entry (when flow is outside initiated) to translate outside-global -> outside-local
From you answer it seem to me ip nat inside destination list/route-map works the same way
If this is right, what are differences between them ?
Thanks a lot
Hi Carlo ,
ip nat outside source lis/route-map - translates the source when flow is entering the outside and going to inside
ip nat inside destination - translate the destination when flow is entering the outside and goint to inside
If it's simple to remember : the command ip nat tells you were is the host/network that will be translated.
Dan
Thinking again about it.......
I think the "right" syntax for destination address translation of packets entering from outside and going to inside should be
ip nat outside destination instead of "ip nat inside destination"
After all here we are translating the Inside global (IG) address into Inside Local (IL) address as destination for a packet entering from outside i/f...
Does it make sense ?
Hi Carlo,
As far as I know "ip nat outside destination" is not available. Destination keyword is only available on ip nat inside and is used for load-balancing.
There are 2 types of nat : static and list ( acl and route-map ). The main difference between them is that static creates a bidirectional translation. This means that , unlinke the 'list' nat, the packet can be originated on any interface (outisde|inside).
In your case you need to configure a static nat. IOS will DNAT in case of a packet arriving on the outside interface with the destination of Outside Global according to your nat statement
Dan
Thanks Dan for the answer....
The spirit of the question asked to clarify doubts about terminology: if I understand correctly the configuration statement ip nat inside destination (used for load-balancing ....) perform translation of packets' destination address entering from outside interface (following configured rules of course)... that address is mapped to a 'real' server address chosen into a 'rotary' servers pool ....
Now, if that is right, the router is translating the inside global address in an inside local (the address of the choosen sever in the pool) ... so, based on this reasonings, I was thinking about the syntax ip nat ouside destination instead of 'ip nat inside destination'....
Carlo
1223
