06-03-2010 05:44 PM - edited 03-04-2019 08:40 AM
I have two sites with 1841 routers connected by a point-to-point T1. From subnet 192.168.1.0 /24 I can access the Internet via RTRA, as well as hosts on the 192.168.1.0/24 subnet, and NAT is working correctly. I cannot access the Internet from RTRB, nor can hosts on the 192.168.0.0/24 subnet, although I can ping the inside (192.168.1.254) and outside (23.154.63.107) interfaces on RTRA. When I try to ping 23.154.63.105 from the 192.168.0.0/24 subnet I get timed out and there are no NAT translations on RTRA:
RTRA#sh ip nat trans
RTRA#
RTRA Partial Config
controller T1 0/0/0
framing esf
linecode b8zs
cablelength long 0db
channel-group 1 timeslots 1-24
interface FastEthernet0/0
ip address 192.168.1.254 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 23.154.63.107 255.255.255.248
ip nat outside
duplex auto
speed auto
interface Serial0/0/0:1
ip address 172.31.2.1 255.255.255.252
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 23.154.63.105
ip route 192.168.0.0 255.255.255.0 172.31.2.2
ip nat inside source list 1 interface FastEthernet0/1 overload
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 1 permit 192.168.1.0 0.0.0.255
RTRB Partial Config
controller T1 0/0/0
framing esf
linecode b8zs
ip address 192.168.0.254 255.255.255.0
ip helper-address 192.168.1.7
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip address 172.31.2.2 255.255.255.252
ip route 0.0.0.0 0.0.0.0 172.31.2.1
Solved! Go to Solution.
06-03-2010 09:48 PM
Hi Michael
Try to adding:
ip nat inside
on
Kamil
06-03-2010 11:12 PM
the ACL should not be any as it is not advised by Cisco.
use this one instead
There is no need of adding T1 interfaces in the ACL as the sources are 192.168.0.0/24 and .1.0/24
and
as suggested by one of the CSC expert configure
ip nat inside on the T1 interface
"ip nat inside"
Hitesh Vinzoda
Please rate useful posts
06-03-2010 06:10 PM
Hi Michael,
Try adding 172.31.2.0/30 to your access list (1) on RTRA and test again.
Reza
06-03-2010 06:31 PM
Reza,
I tried that as well as just doing a permit any to take the ACL out of the equation. Still not NAT'ing.
-mike
06-03-2010 11:12 PM
and
"ip nat inside"
Hitesh Vinzoda
06-03-2010 09:48 PM
Hi Michael
Try to adding:
ip nat inside
on
Kamil
06-04-2010 05:40 AM
Adding ip nat inside to my serial interface on RTRA did the trick and it's working now.
Thanks!
-mike
