NAT overload
rajeshk200_2
Hi there,
I know we can translate multiple inside IP's to single IP by configuring PAT,
Is it possile to NAT multiple outside IP's into single IP?
Many thanks,
Raj
8 Replies 8
Jon Marshall
Raj
On a router no. You can translate multiple outside IP's to a range of inside IP's but not just one as there is no "overload" keyword option when doing "ip nat outside ..."
On a Pix/ASA yes this is very easy to do.
Jon
adamclarkuk_2
Level 4
Level 4
[Edit]
Sorry, Jon is right, I missed the no overload option.
You can do this.
By doing ip nat inside source list x interface x overload for example, you are doing source address translation. You need to do destination address translation using the ip nat outside command:-
ip nat outside source list x pool x
If oyu only define a single IP address in your pool, then you have got what you need.
IP NAT outside config guide.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080093f8e.shtml
Adam
Must admit i have never understood why this functionality is not available on a router.
I have used this functionality on a Pix/Asa quite a few times and it can be quite handy in certain cases.
Perhaps i should just submit a feature request :-)
Jon
What would be the command on PIX/ASA to overload outside NAT ?
Raj.
Lets say you wanted to translate all outside addresses with a source of 192.168.5.0/24 to 172.16.10.1 on the inside
nat (outside) 1 192.168.5.0 255.255.255.0 outside
global (inside) 1 172.16.10.1
Jon
Jon,
Thanks for the response
Is this works along with inside IP translation as well, I mean both way translation concurrently.
nat (inside) 1 0 0
global (outside) 192.168.6.1
Raj
Raj
Yes it should do but to be on the safe use a different NAT id ie.
nat (outside) 2 ...
global (inside) 2
Jon
Jon,
it works , thanks
Raj
