NAT pool configuration
I am creating a NAT pool with a single start ip and end ip .. eg ip nat pool net-45-126 58.2.1.126 58.2.1.126 netmask 255.255.255.0
Is it possible ?
Re: NAT pool configuration
Hi Kaustav,
Yes that is possible for sure.
Have a look at this link for more NAT examples
http://www.cisco.com/warp/public/556/12.html#6>
Also for your requirement you can check the section
"Configuring NAT to Allow Internal Users to Access the Internet Using Overloading" in the link which I have posted above and that example is using the single start and end ip.
HTH, if yes please rate the post.
Ankur
HI
Dear Ankur ;
congrats ! Good to see u with Cisco Systems .
Mahmood
With ref to my earlier config of nat pool ...
ip nat inside source list 111 pool net-45-126 overload .. Do i have to add overload too ?
Regs
Kas
HI
If u r using a pool u need not use the overlaod.
if u r using a sigle IP for NAT u need to use the overlaod as it is called as PAT.
Mahmood
hi Kas,
when ever you are having enough public ip to nat the your local lan private ip then you donot need to use the overload...but let say you are having one golbale ip and having 3 lan host with private ip then you need to have NAT with the overload keyword...which allow your multiple LAN host to connect internet with only one global ip address.
hope this will clear your idea when to use overload...
rate this post if it helps
regards
Devang
333
