NAT port translation from more than one WAN at the same time
Heres the scenario - I have a 2811 Router and have two wics for failover and load balancing. This is working ok.
However the NAT port 25 translation only works on one WAN address at a time, and it seems to switch from one to the other whenever it feels like it and when a fail happens, but would like it to be available on both WAN addresses at the same time.
Below is my running script the two IP addresses are the static WAN addresses given by my ISP which are recieved automatically
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$
ip address 192.168.4.253 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex half
speed auto
no mop enabled
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/0/0.1 point-to-point
pvc 0/38
oam-pvc manage
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface ATM0/1/0
no ip address
interface ATM0/1/0.2 point-to-point
pvc 0/38
oam-pvc manage
dialer pool-member 2
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname username
ppp chap password 0 password
interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 2
ppp chap hostname username ppp chap password 0 password
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat log translations syslog
ip nat pool ISP2 213.x.237.x.218.237.16 netmask 255.255.255.255
ip nat pool ISP1 213.x.237.x.218.237.7 netmask 255.255.255.255
ip nat inside source route-map ISP1-map interface Dialer0 overload
ip nat inside source route-map ISP2-map interface Dialer1 overload
ip nat inside source static tcp 192.168.4.1 25 213.218.237.16 25 extendable
ip nat inside source static tcp 192.168.4.1 25 213.218.237.7 25 extendable
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
route-map ISP2-map permit 10
match interface Dialer1
route-map ISP1-map permit 10
match interface Dialer0
Silver
Re: NAT port translation from more than one WAN at the same time
Please check below link :
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_white_paper09186a0080091cb9.shtml
It stated :
Once that is working, they might also want to define static mappings for a particular host using each provider's address space. The software does not allow two static translations with the same local address, though, because it is ambiguous from the inside. The router will accept these static translations and resolve the ambiguity by creating full translations (all addresses and ports) if the static translations are marked as "extendable". For a new outside-to-inside flow, the appropriate static entry will act as a template for a full translation. For a new inside-to-outside flow, the dynamic route-map rules will be used to create a full translation.
Can you confirm is there any outside-to-inside traffic for the second static NAT rule w/ extendable ?
If it is only triggered by inside-to-outside, there may be only one static NAT rule is used.
Hope this helps.
The translation is from outside to inside.
What I am aiming at is the two adsl lines will both accept incoming SMTP on port 25 at the same time and forward it to 192.168.4.1
At present they will only do one at a time, if i down one dialer or set the route cost higher on one dialer then it will translate and visa-versa on the second wic.
I am not really interested in load balancing them just as long as they forward to the same or another address, as i have two lan ports.
However even when i forward port 25 to two different addresses from the two different public ip addresses it doesn't work until i down one wic.
Many thanks
Paul
Silver
Thanks for the clarification. Could you advise how do you control and ensure the SMTP traffic from out-to-inside that flow to the preferred DSL ? The ISPs will advertise the route to Internet, the incoming traffic depends on the ISP & Internet routing table.
If you manual control the routing table in router, it is for the inside-to-outside traffic. It is true that if you fine tune the cost and the traffic flow to defined DSL w/ NAT. Otherwise, if there is SMTP traffic from outside-to-inside to both DSL, then it should work but inside-to-outside still use one DSL only at a time. Thx.
I think this is where the problem lies. I thought that the two below commands would do that as they are the two public IP addresses that my ISP gave me for each ADSL connection. Dialer 0 being 213.218.237.7 and Dialer 1 being 213.218.237.16
Is this not the case? Any advise would be greatly appreciated.
Silver
According to the config guide. Your command is correct but it works for outside-to-inside traffic or one of the link down and also work for inside-to-outside.
Can you advise how do you test (or prove the NAT is not working) the inside-to-outside traffic if you load-sharing two DSL links ?
Thx.
Hall of Fame Super Gold
To add to the input from Jackyoung and Paul, since it is necessary to map your mail server to two external addresses, you can declare to equal preference MX handlers in DNS, using an address from each provider space. On the server, you will add another address on the LAN, this is done diferently depending on the OS. You will configure two static translations pairing internal and external addresses. This way you will receive email using both circuits normally, and one only in case of failure.
This sounds like expected behavior. There is only one default gateway, so when your router tries to respond to connection attempts on the "second" DSL line, it actually uses the first dsl line because that's the default gateway. When you change the admin distance, you are really just changing the route to 0.0.0.0/0.0.0.0. You may find help with pbr routing.
HTH.
CJL
Cisco Systems, Inc.
Silver
Hi CJL, could you explain why you said there is one GW ? There are two default routes w/ same AD and the router is the local GW for the server. Many thx.
Hey Jack - It's just a guess on my part but I think as the router balances between the two dialer interfaces, inbound connection attemps will be intermittant. At least in this scenario, the router is ultimately flapping the default route between the two interfaces with the same admin distance.
The router decides where to send packets based on where they're going, not where they're from. So, the incoming interface is not part of the forwarding logic. As it replies to the inbound connection attemps, the packet header can contain a different source address than what the other end is expecting.
If an inbound connection attempt is made on Dialer0 port 25, it gets forwarded to the internal mailserver. The mail server responds and the NAT process takes place. When the router sends that response back out it will use whatever happens to be the default gw at the time. If it happens to go out on Dialer1 the connection will fail. Once it's established, the router will be stateful and connections will stay up.
If we take NAT out of the equation this problem won't exist because the source address would be the actual mailserver and the remote side wouldn't care how packets get there.
HTH.
CJL
Cisco Systems, Inc.
This is exactly what i am seeing.
Is there a solution to this that you can base my configuration on.
I thought I had a policy based route by the route maps but i do not think this is working at all.
Help is greatly appreciated
Pls see my post above
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=WAN%2C%20Routing%20and%20Switching&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddcaef6/8#selected_message
I think that once you configure two addresses on the server and two non ambiguous translation, you will be able to have this working.
already tried this, as well as having it on a seperate lan interface (as the 2811 has two).
It didn't work either unless one WAN was down.
It should be something quite simple i would imagine, but looking at other peoples posts on multiple adsl it doesn't look that way
I was thinking about all this and there may be implications depending on the order in which the inside interface processes PBR and NAT, thing that I'm not sure about.
So I would need to lab this out before saying for sure.
I hope to be able to do that after I'm back from a trip I'm taking now.
Silver
Hi CJL, thanks a lot for the clarification. In fact, this is what I found in this case but not understand your meaning in pervious post, so I asked for clarification. Thanks again.
Hi Paul, is your ultimate goal is to load-sharing both incoming & outgoing SMTP traffic ? If this is the case, is it possible to have two LAN interfaces at the mail server then there will be two NAT rule for two LAN interface and it will not create the problem.
Hope this helps.
Yes two interfaces would be ok.
I have already done this however, and it doesn't seem to make a difference.
do you need an ip route 0.0.0.0 0.0.0.0 DialerX command, or is there a way to do this by using a route-map. As this is what seems to be the problem as it always seems that the default gateway is Dialer0
Silver
CAn you share the config. of the router ? If you have two interfaces in mail server, they are located at different subnet. You can configure two NAT rule for them. One NAT for ISP1 and another for ISP2. Then there is no need to use "extendable" and both NAT will be active.
I prefer to use PBR instead of static route, e.g. if the traffic arrived from Ethernet 1 of the router, it will forward to the ISP2 by PBR. Otherwise, the traffic will follow the routing table (assume to have one static route and point to ISP2, one floating static and point to ISP2) to forward the traffic to ISP1.
Hope this helps.
Silver
Sorry, the statment before last statment should be "(assume to have one static route and point to ISP1.....", it should be ISP1, I assume Ethernet 0 connects to first LAN card in mail server and Ethernet 1 connects to second LAN card in mail server.
I've ammended my script to use route maps for the two ISP's to two lan's, but it still isn't playing ball. Heres my latest script
!This is the running config of the router: 192.168.4.253
!version 12.4
hostname ROUTER
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret xxxx
enable password xxx
no aaa new-model
resource policy
ip subnet-zero
ip cef
ip domain name yourdomain.com
ip name-server 213.x.128.x
ip nat inside
duplex half
speed auto
no mop enabled
interface FastEthernet0/1
ip address 172.16.0.253 255.255.0.0
ip nat inside
duplex auto
speed auto
interface ATM0/0/0
no ip address
pvc 0/38
oam-pvc manage
interface ATM0/1/0
no ip address
pvc 0/38
oam-pvc manage
interface Dialer0
ip nat outside
encapsulation ppp
ip policy route-map ISP1-map
dialer pool 1
dialer-group 1
ppp chap hostname USERNAME
ppp chap password 0 PASSWORD
interface Dialer1
ip nat outside
encapsulation ppp
ip policy route-map ISP2-map
dialer pool 2
dialer-group 2
router ospf 1
log-adjacency-changes
maximum-paths 2
ip classless
ip http server
ip nat inside source static tcp 172.16.0.1 25 interface Dialer1 25
ip nat inside source static tcp 192.168.4.1 25 interface Dialer0 25
access-list 130 permit ip 192.168.4.0 0.0.0.255 any
access-list 131 permit ip 172.16.0.0 0.0.255.255 any
route-map ISP2-map permit 131
match ip address 131
set ip next-hop dynamic dhcp
route-map ISP1-map permit 130
match ip address 130
control-plane
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
password PASSWORD
login local
transport input telnet ssh
line vty 5 15
privilege level 15
password PASSWORD
login local
scheduler allocate 20000 1000
end
Silver
You should apply the policy at the incoming interface, i.e. FE0 & FE1 instead of Dialer interface.
Moreover, you do not require to use two separated access-list. Because all traffic from FE0 from forward to Dialer 0, so only require an ACL as below :
access-list 100 permit ip any any
or
access-list 1 permit ip any
then apply above access-list to the route-map.
Only one FE require policy and the other require floating static for backup.
i.e. remove route-map ISP1, corresponding policy at interface and "ip route 0.0.0.0 0.0.0.0 dialer1"
add "ip route 0.0.0.0 0.0.0.0 dialer 1 200"
It means the traffic from FE0 will follow the routing table (i.e. dialer 0 as next-hop)and the traffic from FE1 will follow the policy to forward to dialer 1. If the dialer 0 down, the floating static route will appear and all traffic will float to dialer 1. If dialer 1 down, the policy will not work and the traffic from FE 1 will also flow to dialer 0.
Hope this helps.
This works in a fail-over environment, but to be honest so did my original script with this route cost.
But what I am trying to achieve is to have incoming connection on both wan interfaces at the same time.
Silver
Due to you are using policy-based routing, once the next-hop of the PBR is available and the policy is applied on the correct interface. The traffic will be forwarded to the next-hop which is indicated in the PBR route-map. In the otherwords, you configured the PBR, it won't follow the routing table. Therefore, no matter you have both static routes w/ no cost paramter, it is no effect.
Please refer to my last post for my idea to have this works. If it is not your preferred operation or traffic flow, please let me know and I try to propose another one.
Moreover, the routing table or static route in a router is for the OUT-GOING traffic only, you cannot control the traffic from incoming side, so even you have two static routes at same cost, the incoming traffic still not be load-shared.
Hope this helps.
Bronze
I'm guessing Paul needs to add route-maps to his NAT statements, kind of like this:
ip nat inside source static tcp 192.168.4.1 25 213.218.237.16 25 route-map ISP1-map extendable
ip nat inside source static tcp 192.168.4.1 25 213.218.237.7 25 route-map ISP2-map extendable
And check to see if you are using load-sharing per destiantion.
I take it you have allready checked for 2 default routes in the routetabel.
186
