Webcast-Catalyst9k
Nat Problem
Nats on one of the examples. My web server local ip 192.168.1.237, public address and port from 80 to i want to redirect to port 80 of 192.168.1.237
"ip nat inside source static tcp 192.168.1.237 80 interface GigabitEthernet0/0 80"
and
"ip nat inside source static tcp 192.168.1.237 80 interface x.x.x.x 80 extendable"
I tried as, ports is open not a problem but not redirect to port 80 of 192.168.1.237
believes that caused server. But both of these existing linksys E4200 router port forwarding is working with. In the same way as I did for the camera does not reach the DVR.
Firstly, I think you need to resolve the DNS server. I'm nat inside her like this;
"ip nat inside source static tcp 192.168.1.227 53 interface GigabitEthernet0/0 53"
Port 53 is open but not redirect
Do you think that might cause or DNS server needs to be done for something different?
Thank you in advance for your help.
My config file this;
http://pastie.org/9395740#
Everyone's tags (1)
43
