nat problem
hi
this is my config ,but i can't ping the gateway & i can't access to internet could you pls tell me what is the problem?interface FastEthernet0/0
ip address 192.168.0.222 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Ethernet1/0
no ip address
half-duplex
interface Ethernet1/1
ip address 213.207.241.29 255.255.252.0
ip nat outside
full-duplex
interface Ethernet1/2
no ip address
--More-- half-duplex
interface Ethernet1/3
no ip address
half-duplex
ip nat pool test 213.207.241.29 213.207.241.29 netmask 255.255.252.0
ip nat inside source list 1 pool test overload
ip classless
ip route 0.0.0.0 0.0.0.0 213.207.240.1
ip http server
access-list 1 permit 192.168.0.0 0.0.255.255
thanks
Re: nat problem
Your config is ok.Just change the wild card to 0.0.0.255
"access-list 1 permit 192.168.0.0 0.0.0.255"
since its a C class subnet.
Alternately you can do following config.
FastEthernet0/0
ip nat inside
duplex auto
speed auto
ip nat outside
full-duplex
ip nat inside source list 1 interface eth1/1 overload
ip classless
Pls rate if it helps.
JD
Re: nat problem
can you ping 213.207.240.1 in your router?
can your pc ping your f0/0?
86
