10-15-2007 01:49 PM - edited 03-03-2019 07:10 PM
I have two ips inside my lan fe0/0/0,
need to translate three public ips to them,
two, to 1, and 1to 1
as follows
189.231.33.12 coming from outside should nat to an inside ip of 10.0.0.10 189.231.33.14 coming from outside should nat to an inside ip of 10.0.0.10
and
189.231.33.15 coming from outside should nat to an inside ip of 10.0.0.21
considering this is the only NAT on the config, and the interfaces are:
fe0/0/0
and
S0/0/0
how this nat should be setup,
thanks
Solved! Go to Solution.
10-15-2007 01:53 PM
hey,
the syntax might be wrong but i know the concept:
1.
put the "ip nat inside\outside" on the relevant interfaces.
2. on global config:
ip nat inside source static 10.0.0.10 189.231.33.12 extendable
ip nat inside source static 10.0.0.10 189.231.33.14 extendable
ip nat inside source static 10.0.0.21 189.231.33.15
you need "extendable" because you map the same inside ip.
10-15-2007 01:53 PM
hey,
1.
10-15-2007 02:03 PM
Thank you so much
Extendable...I like that.
resolved it.
