05-01-2008 05:20 AM - edited 03-03-2019 09:47 PM
Hi all,
i've got this situation:
policy src nat from 1 specific IP to some other, it works, if i contact from 1.1.1.1 --> 2.2.2.2 port 23 i've translated src 1.1.1.1 to 3.3.3.3 and if i contact 1.1.1.1 --> 4.4.4.4 port 22 i've translated src 1.1.1.1 to 5.5.5.5.
But i need also comunication from 7.7.7.7 to my 1.1.1.1 port 23 and 8.8.8.8 to my 1.1.1.1 port 23 translation. I mean 7.7.7.7 contact my real 1.1.1.1 but pointing to address 9.9.9.9 and 8.8.8.8 contact my 1.1.1.1 but pointing to address 10.10.10.10.
so i need a kind of policy NAT from outside world destination point of view.
do you think is possible?
thk
dan
Solved! Go to Solution.
05-07-2008 01:49 PM
For the configuration nat for Outside-to-Inside Support Design follow the steps :
1. enable
2. configure terminal
3. ip nat pool name start-ip end-ip netmask netmask
4. ip nat pool name start-ip end-ip netmask netmask
5. ip nat inside source rout-map name pool name [reversible]
6. ip nat inside source rout-map name pool name [reversible]
05-07-2008 03:51 PM
Dan,
If I understood your requirement correctly you should be able to get this to work by using route maps with static translations. It's a cool feature and I can see it working. Try this and let us know how you did.
ip nat inside source static 1.1.1.1 3.3.3.3 route-map test
ip nat inside source static 1.1.1.1 9.9.9.9 route-map test2
route-map test
match ip address 150
route-map test2
match ip address 160
access-list 150 permit tcp host 1.1.1.1 host 2.2.2.2 eq 23
access-list 160 permit tcp host 7.7.7.7 host 9.9.9.9 eq 23
Sundar
05-07-2008 01:49 PM
1. enable
05-07-2008 03:51 PM
Dan,
route-map test
route-map test2
Sundar
