07-06-2006 08:15 PM - edited 03-03-2019 01:15 PM
If i would like to know the timeout of dynamic NAT on my router , what's the command i should use ? and if i haven't set the timout , by default what's the timeout value of dynamic NAT translate ?
thanks
07-06-2006 09:05 PM
AFAIK if you have not configured overloading the default time out would be 24 hours.
To change the default timeout, enter the following commands :-
- enable
- configure terminal
- ip nat translation timeout 'seconds'
Hope it helps.
Please rate all helpful posts.
AbhisheK
07-06-2006 10:21 PM
If i use NAT overload , by default what's the timeout value for dynamic NAT translate?
Thanks AbhisheK for reply
07-07-2006 08:25 PM
Hi!
AFAIK the timeout still remains the same for dynamic NAT with overloading. The only thing is that you have greater control in changing the default time out period when using overloading. So you can change the default time out for each entry.
Enter the following commands to change the default timeout period when using overloading:
- enable
- ip nat translation udp-timeout 'seconds'
- ip nat translation dns-timeout 'seconds'
- ip nat translation tcp-timeout 'seconds'
- ip nat translation icmp-timeout 'seconds'
- ip nat translation syn-timeout 'seconds'
- ip nat translation finrst-timeout 'seconds'
Hope it helps,
Please rate all posts.
AbhisheK
