05-10-2006 03:47 AM - edited 03-03-2019 12:38 PM
I have configured Static nat.
when i am trying to remove the static nat entry i am getting an warning message %translations not found.I removed the ip nat inside and ip nat outside statemetn and cleared the nat translation entries from the router.Then again i tried to remove it,but still the same warning message i am getting and when i am seeing the sh run configs the static nat entry is still there.
IOS (tm) 3700 Software (C3725-IS-M), Version 12.3(10b).Please let me know if u have some solutions.
05-10-2006 03:51 AM
hello,
I think that as far as you clear the nat the is traffic that initaite it again.
May be you need to stop the traffic that is using nat (blocking local source that use nat, or shut interface if possible ) then clear and remove config.
cisand
05-10-2006 06:31 AM
This is because the translation is active. You need to terminate this translation.
You can do this,
"clear ip nat trans *"
and then "no ip nat....."
but you need to do it fast, is better if you have two sessions, one for clear and second for no.
05-11-2006 06:11 AM
hello again,
here is cisco link that explain how to do this
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094422.shtml#stopping
cisand
