Natting from outside to inside
Hi Folks,
I need a  little help, how do I nat from outside to inside? I need to allow connection to my outside ip address from SIP provider and then pass it to the sip server which has a private/internal.
Thank you in advanced I appreciate it.
JP
Re: Natting from outside to inside
Hi Joseph,
you can do the following commands;
1.  ip nat inside source static SIP_INTERNAL_IP interface OUTSIDE_INTERFACE
        i use the outside interface IP, our you can use the same subnet IP of your outside interface connected to your ISP.
or if you want to specify only the specific ports for SIP to SIP communications, but this is applicable to TCp
2. ip nat inside source static tcp SIP_INTERNAL_IP PORT interface OUTSIDE_INTERFACE PORT
hope it answers your question.s
marlon
This is just an example for port 23 (telnet)
interface e0
description LAN interface
ip address 10.10.10.254 255.255.255.0
ip nat inside
interface s0
description WAN interface
ip address 172.16.130.2 255.255.255.0
ip nat outside
ip nat inside source static tcp 10.10.10.1 23 172.16.130.2 23
Meaning that any packet received on destination 172.16.130.2 port 23/TCP
will be forwarded to internal server 10.10.10.1 on port 23/TCP
You have to adjust this example to fit your scenario (IP, PORT, PROTOCOL)
I hope this helps you!
Hi Folks,
JP
Hi JP,
Check out the below link for natting configuration on Cisco with various types, Hope to Help !!
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml
Ganesh.H
165
