Natting help on cisco 2911
hi all experts
we got a new router thats only used for VOIP.
Here i need to do natting. can any one please help me on how to achieve this on cisco 2911 router.
can anyone please show me a ssample config. for the below requirement.
1. ISP:
outisde
Lan Ips:
182.74.152.42
255.255.255.248
gateway: 187.74.152.41
WAN IP's: 182.72.XX.XXX  and 182.72.XX.XXY
2. Inside :
subnet: 10.10.45.0/24 -----------------------to be natted to single pUblic IP 182.72.XX.XXY      (here we use only VOIP phones)
aestrik server: 10.10.45.151 --------------------to be natted to public IP  182.72.XX.XXX with service running ex: udp 5060,5085   and  only  to allow access to
  77.XX.XX.0/255.255.255.0 and restrict access to all other IPs from internet to access aestrik server.
as 10.10.45.151< -----should be accessable with public ip on port 5060 etc. ----------------> 77.XX.XX.0/24   ,    rest all to denied.
so Whats the better way
Im really poor in understanding how this has to be done. so want to clear out the things.
How to proceed on with this.
thanks & regards
srikanth
Hi Srikanth,
See the simple example config.
interface GigabitEthernet0/0
ip address 182.74.152.42 255.255.255.248
ip nat outside
interface GigabitEthernet0/1
ip address 10.10.45.1 255.255.255.0
ip nat outside
ip route 0.0.0.0 0.0.0.0 187.74.152.41
ip nat pool NAT-POOL 182.74.152.43 182.74.152.4. netmask 255.255.255.248
ip nat outside source list MATCH-DST pool NAT-POOL
ip access-list extended MATCH-DST
permit ip any 10.10.45.1 0.0.0.255
route-map NAT-TO-LO0 permit 10
match ip address MATCH-DST
Let us know still if you need any more.
Please rate the helpfull posts.
Naidu.
Hi Srikanth,
You can also check the below link which explained step by step which required.
http://www.tech-recipes.com/rx/713/cisco_how_to_configure_nat_network_address_translation/
Naidu.
Hi naidu
thanks for the quick reply
but how about this
aestrik server: 10.10.45.151 --------------------to be natted to public IP  182.72.XX.XXX with service running ex: port 22
to be allowed to access with only 77.XX.XX.0/255.255.255.0 and restrict access to all other IPs from internet to
example:
source:77.xx.xx.o/24
destination: 182.72.xx.xxx  --------public IP of 10.10.14.151 aestrik server.
port:22
action: allowed
restrict all other IPS to access this IP from outside
Hi Srikanth,
You can achieve that by applying the route-map to static nat statement like below config and this is what I have for one of my customer and working perfect.
ip nat inside source static tcp 10.15.1.10 22 182.72.xx.xxx 22 route-map WAN-OUT extendable
route-map WAN-OUT permit 10
match ip address wanaccess
ip access-list extended wanaccess
permit ip any 77.xx.xx.o 0.0.0.255
deny any any
Naidu.
thanks for ur time
ip nat inside source static tcp 10.15.1.10 22 182.72.xx.xxx 22 route-map WAN-OUT extendable (as mentioned above)
1. can u give me what exactly the differnece betweeen inside and outside for (ip nat inside /outside source static) .
2. and if i have configured as like above 2 updates as stated by u for natting to an  aestrik server to 1 public ip and inside subnet to 1 public ip.
can i able to achieve the below requirement.
subnet: 10.10.45.0/24 -----------------------to be natted to single pUblic IP 182.72.55.57/30      (here we use only VOIP phones)
aestrik server: 10.10.45.151 --------------------to be natted to public IP  182.72.55.58/30 with service running ex: udp 5060,5085   and  only  to allow access to
thanks for helping me out. now i got an idea on this nat but need to clarify the things prior implementing it practically by tomorrow.
thanks srikanth
Hi Srikanth,
It is a dynamic nat and the source list which can be nated and talk with internet with the NAT-POOL 182.74.152.43 182.74.152.4
It is a static nat, means when it go to internet it will go with the specific nated ip only. It wont fall under the global dynamic nat.
For this is what I suggested something like below in my previous post.
ip nat inside source static udp 10.10.45.151 5060 182.72.55.58 5060 route-map WAN-OUT extendable
ip nat inside source static udp 10.10.45.151 5085 182.72.55.58 5085 route-map WAN-OUT extendable
deny any any
Naidu.
557
