NBAR and match protocol
is it necessary to turn on NBAR for command "match protocol" even the protocol is very command protocol "smtp", "DNS", etc?
if no, when shall we turn on NBAR?
1 ACCEPTED SOLUTION
Re: NBAR and match protocol
as soon as u enter the config in the MQC and if u want to use the above statement NBAR is automatically turned on.
If u dnot want to use NBAR then u can use access-lists.
Mahmood
Mahmood
Super Bronze
"is it necessary to turn on NBAR for command "match protocol" even the protocol is very command protocol "smtp", "DNS", etc? "
No, as Mahmood also notes.
"if no, when shall we turn on NBAR?"
If you need to do NBAR protocol discovery.
276
