09-28-2007 05:27 AM - edited 03-03-2019 06:57 PM
Has anyone managed to get an 1841 with the ADSL port to get on the Internet? I have connected but get no web pages.
Here are parts of the config I use:
ip dhcp pool client
import all
network 172.19.16.0 255.255.255.0
default-router 172.19.16.1
lease 0 2
interface ATM0
no ip address
no ip unreachables
no ip mroute-cache
atm vc-per-vp 64
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
cdp enable
interface FastEthernet0/0
ip address 172.19.16.1 255.255.255.0
no ip unreachables
ip nat inside
ip virtual-reassembly
hold-queue 100 out
interface Dialer1
ip address negotiated
no ip unreachables
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname 123456789@hg57.btclick.com
ppp chap password 0 123456789
ppp pap sent-username 123456789@hg57.btclick.com password 0 123456789
ppp ipcp dns request
ppp ipcp wins request
ip route 0.0.0.0 0.0.0.0 Dialer1
ip nat inside source list 102 interface Dialer1 overload
access-list 102 permit ip 172.19.16.0 0.0.0.255 any
dialer-list 1 protocol ip permit
09-28-2007 06:07 AM
Try this link http://www.cisco.com/en/US/tech/tk175/tk15/tech_configuration_examples_list.html it has everything about ADSL whatever the router model you have.
Dandy
09-28-2007 06:46 AM
Thanks!
What I did notice was though if I ping from the routers console say www.google.com it would resolve successfully. From a laptop it won't but will if I put the IP of google's website in. I thought the import all option in DHCP would get the user to use the ISP's DNS servers?
09-28-2007 07:02 AM
In your laptop MS-DOS CLI, execute "ipconfig /all" and check if you have a DNS. If none, follow the guide to include the DNS in the DHCP.
Can you check also the output of "show ip dhcp import" from the router if it returns with a DNS entry?
Dandy
10-24-2007 12:03 PM
did you solve this issue I have the same problem
10-24-2007 02:04 PM
Hi, how far have you got, mines all working. All I had to do was add an Internet DNS server IP in the DHCP part.
Can you PC get onto Google by the IP, 72.14.207.99?
If so then its a simple DNS issue mentioned above.
Please rate this post
10-24-2007 02:09 PM
Man the issue looks very similar but instead a DNS ip address I just put this command on my internal interface ip tcp adjust-mss 1452 and this command on my dialer interface mtu 1492, then everything works!
10-24-2007 02:18 PM
Great, where did you get those settings from? It worries me that never set these mtu settings, everything works, but I wonder if things would be better if I did?
10-29-2007 09:30 AM
See link bellow! this issue is common when you have dls to internet and nat configured
This is very good link
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a008071a7c2.shtml
