Webcast-Catalyst9k
Need a Document which describes VRRP.
Silver
Re: Need a Document which describes VRRP.
Thanks Balaji. Do you have an entire link which gives info from top-bottom on VRRP.( i mean from basic-configuring-load balancing- and troubleshooting).
I would appreciate your help on this.
hi,
here you go for more detail on it:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hiap_c/ch20/haipvrrp.htm
please rate this post if it helps
regards
Devang
Thank U so much.
127
