03-24-2008 05:19 AM - edited 03-03-2019 09:14 PM
Hi all,
I need arouter that will be haivng all the features that i am listing below.
1.Multi Processor Architecture
2.Two synchronous WAN port with DTE speeds upto 2.048 MBPS should connect to fractional E1 (G.703)
3.One Ethernet LAN connection 10 Base-T
4.Inbuilt CSU/DSU
5.Flash Memory 2 MB
6.SRAM 6 MB
7.LED's for WAN and LAN status
8.RS-232 interface for local configuration
9.Software Upgradeable
10.CAM (16 Kilo Words) based Router Accelerator Mobile
11.Long Haul E1
12.Class 5 Telecommunication Grade Design
13.Complaint to TEC-QM-333 specification.
14.Convention cooling, no forced cooling
15.19 inch Rack mount design
16.Operating Voltage -48 V DC
17.Operational as per Installation diagram in Drop Insert Mode
18.Make: RAD
Please help me in sloving this case.
03-24-2008 05:41 AM
That's an easy bid to answer, look at point 18 and search among products of that manufacturer, not cisco.
03-24-2008 06:17 AM
you can consult your boss to isolate some lists that are not related to Cisco products!
