02-09-2012 11:29 PM - edited 03-04-2019 03:12 PM
Hi folks,
I have a small office with about 20 people. I currently have a T1 line which feeds a Cisco ASA 5505. I would like to replace the T1 line with two (2) ADSL lines. I need a dual WAN switch/load balancer. I researched a bit and found that Cisco RV042 will probably work for me even though I don't need another VPN and would have to disable it.
My question: Is there anothe device from Cisco or others which will give me the dual WAN and load balancing but not the VPN piece. My assumption is that it would be a less expensive device if such an animal exists.
Thank you in advance for any advice you could impart.
N.G.
02-10-2012 12:37 AM
any router with 2 outside interfaces will be able to load balance.
Regards.
Alain
02-10-2012 06:13 AM
Thanks for your response.
Could anyone recommend a good unit? I poked around a bit; ostensibly, some of thes units do less load balancing and more fail-over. It is critical for me to be able to take full advantage of both lines concurrently and fully.
Thanks!
