Need example configuration for vwic-1mft-E1(data) on Cisco1760
Hi all,
My company just purchased 2Xvwic-1mft-E1
for Cisco1760. The evironment as follows:
[1760]--[vwic-1mft-E1]--ISP--[vwic-1mft-E1]--[1760]
Could someone please provide me
the example configuration for both
routers ?
Thanks so much : )
Gold
Re: Need example configuration for vwic-1mft-E1(data) on Cisco17
Not sure what part you need help with. I will assume just the card itself.
The basic stuff to get started is. (assuming your card is in slot 1/0)
controller e1 1/0
channel-group 0 timeslot 1-31
serial 1/0:0
ip address 1.2.3.4 x.x.x.x
This may be all you need if you are lucky and you can use all the default line encoding and you are not running a fractional e1. All things releated to the csu/dsu function are configured under the controller and the rest is under the serial line.
Take the following from ur ISP
(1)Time slots alloted to u.
(2)Framing
(3)line code.
The default 2mb unframed settings in my country will be:
controller e1 0
channel-group 0 time-slots 1-31 speed 64
framing no-crc-4
linecode HDB3
clock source line
Then an serial interface will pop up
interface serial 0:0
ip add x.x.x.x x.x.x.x
encap ppp
Revert back if any probs.
Rate if this had helped.
JD
199
