Need for threshold values recommendations
Does anybody know if  there are any documents  by Cisco Systems, containing recommendations for  the following values:
- maximum acceptable (threshold) level of  five minutes CPU Utilization, % ( routers, switches)
- maximum acceptable (threshold) level of free memory, memory used.
- maximum acceptable (threshold) level of proportion unicast/not unicast traffic
Thanks in advance.
  • WAN Routing and Switching
Everyone's tags (1)
Bronze
Re: Need for threshold values recommendations
I am not aware of any Cisco document advicing about the proper values. But they can be considered as follows:
- maximum acceptable (threshold) level of  five minutes CPU Utilization, % ( routers, switches):
     The lower the better. Although each platform has a minimum CPU usage. i.e. 3550 switches tend to have a minimum of 35 - 40% of CPU usage dedicated to their internal management functions.
- maximum acceptable (threshold) level of free memory, memory used:
     The higher the better. In addition having no memory fragmentation is very important too to be able to allocate every process needed.
     The lower the proportion the better. Although the not unicast traffic levels will depend on the type of traffic traversing an interface, A percentage above the 85 - 90% may impact the link and switch/router performance.
Hope this helps.
Thanks a lot!
577
