Need help setting up this WAN.
V3teran75
I have been assigned to setup this wan and ive got very far into it but im struggling with the next part which i think maybe down to the way that it is worded. There are very specific instructions for this on the pkt file, is it possible for somebody to take alook at this for me please?
Thanks in advance.
Paul
On each router you haven't added under the RIP config the subnet used to connect the two routers together. With RIP/EIGRP/OSPF the network command under the router config tells the router which interfaces to run on and because you haven't included them RIP is not running on those interfaces. So on each router -
router rip
network 200.100.85.0
Can you modify your configs and then see if you are seeing routes on gateway2 received from the gateway router.
Jon
14 Replies 14
Jon Marshall
Paul
A lot of us don't use PT and therefore can't read those files. If you upload a screenshot of the topology plus a problem description then you may find a lot more people can help.
Jon
Well some people may use it, i hope somebody who uses it comes into this thread.
How do i upload a picture, this website is terrible for hosting picture links that ive tried to upload.
Paul
they do and if you want to wait to see if anyone responds then that's fine.  I was simply trying to make sure you got the help you needed.
Save the screenshot as a jpg/png and upload.
Jon
cadet alain
Which task are you stuck at ?
Alain
Ok here are my configs, im trying to ping gateway and gateway 2, there both routers from the public server. I can ping gateway from the public server but not gateway2
I have also used ripv2 by using configure terminal, router rip,version 2.(in the cisco IOS commandline within the router)
Here is my pictures, ive been on this for a couple of hours now and im stuck, it should be simple but its not working
Paul
gateway2 obviously doesn't have a route back to the public server.
Can you post -
1) the IP of the server
2) the configs for both routers
Jon
The ip of the server is 172.16.100.10/255.255.255.252
When you say the configs for both routers do you mean the show run command?
cheers
Paul
Yes, the configs would be the "sh run" command.
If you do a "sh ip route 172.16.100.0 255.255.255.252" on gateway2 can you see a route for it pointing to the gateway router ?
If not that is the issue and it may be because of the RIP config but it would be handy to see the interface configurations as well so we can see the IP addressing being used for all the links.
Jon
Gateway show ip route
Gateway# show  ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is 200.100.85.1 to network 0.0.0.0
     172.16.0.0/24 is subnetted, 1 subnets
C       172.16.100.0 is directly connected, FastEthernet0/0
C    192.168.1.0/24 is directly connected, FastEthernet0/1.1
C    192.168.10.0/24 is directly connected, FastEthernet0/1.10
C    192.168.20.0/24 is directly connected, FastEthernet0/1.20
C    192.168.30.0/24 is directly connected, FastEthernet0/1.30
C    192.168.40.0/24 is directly connected, FastEthernet0/1.40
C    192.168.50.0/24 is directly connected, FastEthernet0/1.50
C    192.168.100.0/24 is directly connected, FastEthernet0/1.100
     200.100.85.0/30 is subnetted, 2 subnets
C       200.100.85.0 is directly connected, Serial0/3/0
C       200.100.85.8 is directly connected, Serial0/3/1
S*   0.0.0.0/0 [1/0] via 200.100.85.1
Gateway#
Gateway show run
Gateway#
Gateway#show run
Building configuration...
Current configuration : 1984 bytes
version 12.3
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Gateway
ip ssh version 1
no ip domain-lookup
spanning-tree mode pvst
interface FastEthernet0/0
description Public Web Server
ip address 172.16.100.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 1 native
interface FastEthernet0/1.10
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
interface FastEthernet0/1.20
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
interface FastEthernet0/1.30
encapsulation dot1Q 30
ip address 192.168.30.1 255.255.255.0
interface FastEthernet0/1.40
encapsulation dot1Q 40
ip address 192.168.40.1 255.255.255.0
interface FastEthernet0/1.50
encapsulation dot1Q 50
ip address 192.168.50.1 255.255.255.0
interface FastEthernet0/1.100
encapsulation dot1Q 100
ip address 192.168.100.1 255.255.255.0
interface Serial0/3/0
description Serial link to "Internet"
ip address 200.100.85.2 255.255.255.252
ip access-group 199 in
clock rate 250000
interface Serial0/3/1
ip address 200.100.85.10 255.255.255.252
clock rate 250000
interface Vlan1
no ip address
shutdown
router rip
version 2
passive-interface Serial0/3/0
network 172.16.0.0
network 192.168.10.0
network 192.168.20.0
network 192.168.30.0
network 192.168.40.0
network 192.168.50.0
network 192.168.100.0
default-information originate
ip classless
ip route 0.0.0.0 0.0.0.0 200.100.85.1
access-list 199 permit tcp any eq www 192.168.0.0 0.0.255.255 established
access-list 199 deny tcp any 192.168.0.0 0.0.255.255 eq www
access-list 199 deny tcp any 192.168.0.0 0.0.255.255 eq telnet
access-list 199 permit ip any any
line con 0
line aux 0
line vty 0 4
password cisco
login
end
Gateway#
Gateway2 show ip route
Router#show ip route
Gateway of last resort is not set
     200.100.85.0/30 is subnetted, 1 subnets
Router#
Router#
Gateway2 show run
Router#show run
Current configuration : 607 bytes
version 12.3
hostname Router
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
no ip address
ip address 200.100.85.9 255.255.255.252
interface Vlan1
no ip address
shutdown
router rip
version 2
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Router#
Here are my GUI pictures of gateway and gateway2 showing RIPv2
I have noticed that the GUI for gateway is preconfigured where gateway2 is not. Could this be the reason for no ping?
I did enter the commandline within each router and enter the command config t, router rip, version 2.
I though this was enough...? Why do i need to enter in the GUI also as shown here??
Thankyou for helping i appreciate it as im stuck, im quite new to cisco and thought i was doing well up to this point.
Paul
router rip
Jon
When you say router rip do you mean do this from the commandline within cisco? or add from the GUI as its shown above?
Paul
Paul
Sorry i was talking about the CLI (command line). I don't have any experience with PT but i believe you can telnet/ssh to the actual device and configure it that way.
Jon
Hi Jon.
Sorry for late reply as been busy with family etc.
Yes it worked once i added this to the routers GUI (RIP)
router rip
Ive rated your post as helpful and there maybe more questions to come in the future.
Thanks again
Paul.
Paul
No problem, glad to have helped and thanks for using the rating system to let us know it worked.
Please feel free to post anytime you need to, there are always people who can help out with any issues.
Jon
