03-28-2014 06:44 AM - edited 03-04-2019 10:40 PM
All,
I am working on setting up a 2811 router to act as a PPPoE client for a newly installed DSL connection. I am running debug on the router and I see the PADISNT going out. I see the PADO coming back to the router. I then see the PADR leaving from the router and finally the PADS coming back from the modem. I also see Vi2 becoming bound to profile Di1. All looks good then I see the modem sending a PADT (termination) then the process repeats. Can anyone shed some light what this terminations are coming back from the modem?
Below are the debug outputs...
minrtr01#debug pppoe ev
000922: Mar 27 16:55:00.937: %DIALER-6-BIND: Interface Vi2 bound to profile Di1ent
PPPoE protocol events debugging is on
minrtr01#
000923: Mar 27 16:55:00.941: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to updebug
000924: Mar 27 16:55:03.393: PPPoE 11990: I PADT R:88e0.f3c8.ee72 L:0023.5e00.4db8 Fa0/0
000925: Mar 27 16:55:03.393: PPPoE : Shutting down client session
000926: Mar 27 16:55:03.393: [0]PPPoE 11990: O PADT R:88e0.f3c8.ee72 L:0023.5e00.4db8 Fa0/0
000927: Mar 27 16:55:03.393: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1pppoe
000928: Mar 27 16:55:03.397: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down pack et
PPPoE control packets debugging is on
minrtr01#
000929: Mar 27 16:55:23.553: Sending PADI: Interface = FastEthernet0/0
000930: Mar 27 16:55:23.553: pppoe_send_padi:
FF FF FF FF FF FF 00 23 5E 00 4D B8 88 63 11 09
00 00 00 0C 01 01 00 00 01 03 00 04 46 AF E4 E4 ...
000931: Mar 27 16:55:23.585: PPPoE 0: I PADO R:88e0.f3c8.ee72 L:0023.5e00.4db8 Fa0/0
00 23 5E 00 4D B8 88 E0 F3 C8 EE 72 88 63 11 07
00 00 00 40 01 02 00 1C 6D 70 6C 73 2D 64 73 6C ...
000932: Mar 27 16:55:25.601: PPPOE: we've got our pado and the pado timer went off
000933: Mar 27 16:55:25.601: OUT PADR from PPPoE Session
88 E0 F3 C8 EE 72 00 23 5E 00 4D B8 88 63 11 19
000934: Mar 27 16:55:25.737: PPPoE 6073: I PADS R:88e0.f3c8.ee72 L:0023.5e00.4db8 Fa0/0
00 23 5E 00 4D B8 88 E0 F3 C8 EE 72 88 63 11 65
17 B9 00 0C 01 01 00 00 01 03 00 04 46 AF E4 E4 ...
000935: Mar 27 16:55:25.737: IN PADS from PPPoE Session
000936: Mar 27 16:55:25.741: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
000937: Mar 27 16:55:25.741: PPPoE: Virtual Access interface obtained.
000938: Mar 27 16:55:25.741: PPPoE : encap string prepared
000939: Mar 27 16:55:25.741: [0]PPPoE 6073: data path set to Virtual Acess
000940: Mar 27 16:55:25.745: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
000941: Mar 27 16:55:28.186: PPPoE 6073: I PADT R:88e0.f3c8.ee72 L:0023.5e00.4db8 Fa0/0
00 23 5E 00 4D B8 88 E0 F3 C8 EE 72 88 63 11 A7
17 B9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ...
000942: Mar 27 16:55:28.190: PPPoE : Shutting down client session
000943: Mar 27 16:55:28.190: [0]PPPoE 6073: O PADT R:88e0.f3c8.ee72 L:0023.5e00.4db8 Fa0/0
88 E0 F3 C8 EE 72 00 23 5E 00 4D B8 88 63 11 A7
000944: Mar 27 16:55:28.190: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
000945: Mar 27 16:55:28.194: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
Adil
03-28-2014 06:57 AM
Could you post output of following:
debug ppp authentication
debug ppp negotiation
BR,
Dragan
