Need help with frame relay switch configuration
asimkamran
Hello everybody,
Here's my setup:
R1 (Hub) has two serial connections to FR switch, R2 and R3 each have one serial connection to FR switch.
Now my question is how can go about assigning the DLCIs? When I try to apply the following command frame-relay route 221 interface serial 1/0 101 and frame-relay route 221 interface serial 1/0 101
it doesn't acccept it saying that you can't have two dlci's assigned to same interface.
If anybody can refer me to any configuration doc for this same scenario I would appreciate.
miguel.rosario
You can only use one dlci per interface at least that you create sub-interface you can asign two dlci or more per interface.
SunilKhanna
Configuration on FRAMERELAY-SWITCH
hostname FRAMERELAY-SWITCH
frame-relay switching
interface Serial1/1
description Frame-Relay Connection to R1
no ip address
encapsulation frame-relay IETF
clock rate 64000
no frame-relay inverse-arp
frame-relay lmi-type ansi
frame-relay intf-type dce
frame-relay route 100 interface Serial1/2 200
interface Serial1/2
description Frame-Relay Connection to R2
no ip address
clock rate 64000
frame-relay route 200 interface Serial1/1 100
Configuration on HOST R1
interface Serial1/0
description frame-relay connection
ip address 192.12.12.1 255.255.255.252
frame-relay map ip 192.12.12.2 100 broadcast
interface Serial1/0
ip address 192.12.12.2 255.255.255.252
frame-relay map ip 192.12.12.1 200 broadcast
Verification
HOST_R2#ping 192.12.12.1
Sending 5, 100-byte ICMP Echos to 192.12.12.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 56/56/60 ms
FRAMERELAY-SWITCH#show frame-relay route
Input Intf      Input Dlci      Output Intf     Output Dlci     Status
Serial1/1       100             Serial1/2       200             active
Serial1/2       200             Serial1/1       100             active
Regards, Sunil Khanna
