Webcast-Catalyst9k
Need Help With PBR
I have configure PBR. The 3 local clients connects internet via Dialer1 interface.
There is Point-to-point connection on Dialer 0 interface.
These 3 clients must route traffic to dialer 0 interface if they want to reach the 192.168.1.0/24 network.
How can I do that?
interface GigabitEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.0.0.254 255.255.255.0
ip virtual-reassembly in
ip tcp adjust-mss 1452
interface GigabitEthernet0/0.60
encapsulation dot1Q 60
ip address 10.0.8.254 255.255.255.0
ip nat inside
ip policy route-map InternetViaADSL
interface GigabitEthernet0/0.100
encapsulation dot1Q 100
ip address 10.0.5.254 255.255.255.0
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 0.0.0.0 0.0.0.0 Dialer1 20
ip access-list extended InternetViaADSL
permit ip host 10.0.8.215 any
permit ip host 10.0.8.216 any
permit ip host 10.0.8.217 any
route-map InternetViaADSL permit 10
match ip address InternetViaADSL
set interface Dialer1
1 ACCEPTED SOLUTION
Need Help With PBR
Murat,
So you want those 3 clients to talk to the HQ subnets as well right? well then you need to slightly change the existing route-map a bit. below is what needs to be there to get what you want
access-list 101 permit ip host 10.0.8.215
access-list 101 permit ip host 10.0.8.216
access-list 101 permit ip host 10.0.8.217
match ip address 101
set interface Dialer0
route-map InternetViaADSL permit 20
Now, route-maps are sequential meaning they get executed in a sequential order just like ACL's
so when your branch tries to access the HQ the first condition will be fulfilled hence the route-map will not go further and the traffic will be sent out via dialer 0
when you access anything other than the HQ subnets the first condition doesnt match and the route-map will further go down to condition 2 and this will match hence traffic will be sent out via dialer 1
Kishore
Purple
Need Help With PBR
Do this:
no ip route 0.0.0.0 0.0.0.0 Dialer0
no ip route 0.0.0.0 0.0.0.0 Dialer1 20
ip nat inside source list 199 NAT interface Dialer1
int Dialer1
ip nat outside
exit
access-list 199 deny ip  host 10.0.8.215 192.168.1.0 0.0.0.255
access-list 199 deny ip  host 10.0.8.216 192.168.1.0 0.0.0.255
access-list 199 deny ip  host 10.0.8.217 192.168.1.0 0.0.0.255
access-list 199 permit ip host 10.0.8.215 any
access-list 199 permit ip host 10.0.8.216 any
access-list 199 permit ip host 10.0.8.217 any
access-list 198 permit ip  host 10.0.8.215 192.168.1.0 0.0.0.255
access-list 198 permit ip  host 10.0.8.216 192.168.1.0 0.0.0.255
access-list 198 permit ip  host 10.0.8.217 192.168.1.0 0.0.0.255
route-map DIALER0
match ip address 198
ip policy route-map DIALER0
Regards.
Alain
Need Help With PBR
Hi Alain;
These 2 subinterfaces must route all traffic to dialer 0 interface. They will connect to internet via headquarter and sources at headquarter.
if I remove routing, no ip route 0.0.0.0 0.0.0.0 Dialer0 , their connection will be dropped
Only GigabitEthernet0/0.60 interface must connect to internet via dialer 1 interface but must be reachable from headquarter (192.168.1.0/24) which comes from dialer 0 interface.
Purple
Need Help With PBR
so can you join a  diagram and explain more thoroughly which traffic goes where and if you want failover or load-balancing and exactly what is the goal of PBR.
Regards.
Alain
Re: Need Help With PBR
Keep your default routing as it is
Assuming that the default route via dialer1 has less administrative distance to route all traffic via dialer1 interface
Use the bellow pbr config to route the traffic out dialer0 for traffic going to network x.x.x.0/25
Access-list 100 permit ip any x.x.x.0 0.0.0.255
Rout-map map1
Match ip address 100
Set ip next-hop y.y.y.y
Where y.y.y.y is the next hop ip of the dialer0 point point link
Then apply the above pbr to desired interfaces/sibinterface
Hope this help
Sorry for the late reply. I am gonna test the configuration.
Here is the diagram:
   Head Quarter Juniper SRX -----------------------Dialer 0---------------------------------- Cisco 2901 (Branch Office) ( Has 2 wan connections )
Cisco 2901 ----------------------Dialer 1 -------------------- Internet
192.168.1.0 - Lan
192.168.5.0 - Voice
Branch Office:
10.0.0.0/24 - Lan
10.0.5.0/24 - Voice
10.0.8.0/24 - Camera
So Here is the deal.
Branch Office Lan and Voice Netwrok - Routes all traffic to dialer 0
Camera Netwrok routes all traffic to dialer 1
So here is the deal,
From headquarter I can reach lan and voice netwrok but I can not reach camera network because it routes all traffic to dialer 1 interface. I want to seperate routes.
IP Cameras has destination nat rule for dialer interface.
Need Help With PBR
Murat,
Kishore
I beleive this should have solved your problem.
Pawan Sharma
http://www.ebrahma.com
Need Help With PBR
Hi Kishore,
It worked. Thanks
Murat
562
