Need Help with Policy based routing on 6500 switch with FWSM.
I have 2 incoming vlans.
interface Vlan2
ip address 10.0.0.11 255.255.255.0
ip flow ingress
ip policy route-map split
standby 2 ip 10.0.0.3
standby 2 priority 110
standby 2 preempt
interface Vlan3
ip address 10.0.1.11 255.255.255.0
ip flow ingress
standby 3 ip 10.0.1.3
standby 3 priority 110
standby 3 preempt
The above 2 are internet facing vlans and i have some internal vlans behind the fwsm. There is a default route in the fwsm which directs all the traffic to vlan 2 and from there depending on the following route-maps it goes out of either vlan2 or vlan3.
route-map split permit 10
match ip address 120
set ip next-hop 10.0.0.10
route-map split permit 20
match ip address 130
set ip next-hop 10.0.1.10
access-list 120 permit ip 172.16.0.0 0.0.0.255 any
access-list 120 permit ip any 172.16.0.0 0.0.0.255
access-list 130 permit ip 172.16.1.0 0.0.0.255 any
access-list 130 permit ip any 172.16.1.0 0.0.0.255
Now i have added another internet facing vlan into the switch which is a vrf.
interface Vlan4
ip vrf forwarding data
ip address 192.168.10.1 255.255.255.0
Now to get some of the traffic to go out of this vrf vlan I made the following changes.
access-list 140 permit ip 172.16.2.0 0.0.0.255 any
access-list 140 permit ip any 172.16.2.0 0.0.0.255
route-map split permit 30
match ip address 140
set vrf data
Also, added the "ip vrf receive data" command on the Vlan2.
After making all the above changes i am still unable to route the 172.16.2.0 network out of the vlan 4.
Can someone help me, if i am doing something wrong. Any help is highly appreciated.
According to me, the mistake i am doing is, if i have to ping out of the vrf, i need to mention the source ip and it should be in the subnet of vrf vlan, But in my case it will be different is the PBR is applied to a different vlan. This is my assumption. If i am correct then can anyone help me out how to correct it or if there is some other issue can anyone let me know how to fix that.
Jeff
277
